Other bulbs in the headlights?
Old Jan 7, 2007 | 06:09 AM
Deivioncrx's Avatar
Does anybody know the model number on the other 2 bulbs in the headlights, the turnsignal and the marker bulb?
Old Jan 7, 2007 | 11:14 AM
spreadhead's Avatar
Front turn signal 992 (7440A), Parking light 2827
Old Jan 7, 2007 | 08:12 PM
j5ive's Avatar
there is actually a sticky in this forum that lists most, if not all of the bulbs used in the Fit.
Old Jan 8, 2007 | 01:39 AM
Deivioncrx's Avatar
ok then another question is there anything else that will fit in the 2827 socket, because im not seeing these anywhere
Old Jan 8, 2007 | 04:12 AM
j5ive's Avatar
if you can, try to keep with a 2827 bulb as it is the European spec wedge bulb, rated with the most light output; at 4 candlepower at 12v (the voltage E-code rates bulbs at). If you really can't find any, 168NA bulb (2.5 candlepower at 14v) and 194NA bulb (1.5 candlepower at 14v) will also fit in the socket, but provide less light output.
Alternatively if you don't want to stick to the yellow (Natural Amber) colour and want clear bulbs, then go with the 2825 bulb (4 candlepower at 12v), 168 (3 candlepower at 14v) or 194 bulb (2 candlepower at 14v) will also work.
2825 and 2827 might be close to 5 or 6 candlepower when at the running voltage of 14v. Much brighter than the 168 or 194 bulbs.
Hope this helps.
Old Jan 8, 2007 | 03:48 PM
Deivioncrx's Avatar
Hope this helps.
ok kool, im realy looking for some of the chrome or silverstar bulbs, that have the coating on them so you dont see the Amber reflection inside the headlight ect..., its my moms car and im not allowed to mod it substantialy so its down to the small "clean" mods
THE_DON
109
Aug 8, 2023 05:03 PM
drock305
Feb 9, 2010 08:06 PM
713_fit
Oct 18, 2009 01:06 AM
bestfit
Feb 1, 2008 04:38 PM
Wave
Jun 16, 2007 05:23 AM
