Cheap Mods to make Base model fit faster
Old Jun 12, 2024 | 03:32 PM
jubyloo's Avatar
I got a 2013 Base Fit. Any cheap mods to improve speed for noticeable gains?
Old Jun 12, 2024 | 08:21 PM
Nothing cheap will make the car notably faster.
follow speed limits and other road safety laws.
Old Jun 13, 2024 | 07:39 AM
PittsPeteFit's Avatar
Yes, sticky tires! Also, actually learn to drive. go AutoX, go karting, track days. We're all crap drivers and are slow because of that.
Old Jun 13, 2024 | 09:15 AM
DTrezs's Avatar
A base fit with the normal bot on parts are just as fast as a stock one. not exactly, but it is way closer than you would think. I say the Fit is grate with good tires because they let you get away with a lot and if you add power then you can't rip around town power shifting and still not even go over the speed limit.
Old Jun 13, 2024 | 10:26 AM
NWCH's Avatar
You can upgrade the intake and exhaust. But the car won't be that much faster, just louder.
Want a faster car? Buy something beside the Fit.
Old Jun 14, 2024 | 01:34 PM
Pyts's Avatar
Cut weight, and ditch the brakes -- they'll only slow you down
Old Jun 14, 2024 | 08:38 PM
overslept's Avatar
Progress Rear Sway Bar
Old Jun 15, 2024 | 03:10 AM
jubyloo's Avatar
So basics like Intake? Filter? Exhaust? Anybody do any dyno tests for real-world gains😂
Old Jun 15, 2024 | 06:33 AM
mobby_6kl's Avatar
I doubt any bolt-ons would make a noticable difference.
Since I did some research for my project, the simplest and cheapest thing that actually does something is probably a small AMR500 supercharger. Compared to a turbo you don't have to touch the exhaust or deal with oil lines and it might even be ok without an intercooler if the boost is low enough. At least on the GD it looks like it might even be possible to stick it in place of the AC compressor, which doesn't work on my car anyway. You'd still have to replace and tune an ECU though and in the end I didn't get into this.
Old Jun 15, 2024 | 07:29 AM
Pyts's Avatar
If you stick a high-flow oiled K&N on it you can get a sweet CEL. Also, if you do intake, the ducting has to be OEM in diameter around the maf.
Zero1000 makes a sick intake. As the son of an AC guy I can say the ducting design looks promising anyways.
uhh. catback exhaust. tanabe medallion touring is a popular one.
when j's racing built a GE they focused on handling mods. same with superstreet/import tuner/whatever garbage company bought them out and ruined their content.
you can get some rays/volk wheels, or rpf1's, or if you want to, sparco now makes some pretty nice budget wheels. I think they're flow formed.. ff7 or something -- weigh like 11lbs for a 15x7.
somebody just did a high-end short shifter. That's a good one for this car. I've just got a buddyclub.
you can get some extra go from denso ik22 spark plugs, but once you touch plugs you're opening the door for the annoying spark plug loosening problem. 20 ftlbs, no anti-seize.
besides the above, boost or swap.
A cool budget mod for me is readjusting valves.
Old Jun 19, 2024 | 03:59 PM
GrE8_Fit's Avatar
Lighter wheels, take the back seat out, new plugs, new filter, clean MAF. Maybe a bottle of injector cleaner. That and a V8 swap.
Old Jun 19, 2024 | 04:32 PM
jubyloo's Avatar
Thanks for all the suggestions. So far got lighter wheels and new wing 😂 was hoping for any dyno results on filters/intake etc
Old Oct 4, 2024 | 01:42 PM
3FITY's Avatar
Boltons are just a placebo for noticeable gains. Add a turbo and tune and you’ll be flying in that Fit
Old Oct 5, 2024 | 01:11 PM
Mister Coffee's Avatar
To paraphrase The Godfather: Leave the brakes, ditch the back seats.
Getting rid of weight (back seats, A/C, radio, spare tire) will increase your power-to-weight ratio.
Xtina
Jun 10, 2016 04:24 AM
wwjd
Oct 19, 2011 07:03 PM
modfit669
Sep 12, 2008 03:51 PM
moc
May 8, 2008 10:30 PM
Volk
Jan 19, 2006 05:54 PM
