Fuel injector replacement
My wife’s 2019 fit is at 106k and needs new injectors.
spent $1300 today to order a set from Oreillys (mainly due to lifetime warranty.)
my question is should I also replace the fuel rail and fuel joint pipe as well?
The manual I’m looking at says replace fuel joint pipe but doesn’t mention fuel rail so I thought I’d seek some advice from others.
I appreciate any help!
Make sure to lube the o-rings and teflon seals on the injectors well before insertion.
Also, it would be a great time to do a valve adjustment and walnut blast the intake valves while everything is apart.
Slick Seal
May 9, 2023 04:03 PM
VelvetB
Nov 3, 2018 11:59 PM
azkikersfit
Sep 29, 2007 12:35 AM
