speaker depths
Old Jan 16, 2007 | 11:56 AM
sillypuddy's Avatar
Someone that Posts too much
speaker depths
I was looking at getting replacement speakers for my 07 fit sport.
does anybody know what is the maximum depth i have to work with? i wanted to get some components, but the magnet is huge (kef's)
-joe
Old Jan 17, 2007 | 04:39 AM
vividjazz's Avatar
67mm without a bit of dremmeling of the inside of the factory plastic door trim or 69mm with. If prepared to completely cut up the inner door trim then even deeper. This is also with the biggest spacers possible. Info can also be found via using Search on the forum
Old Jan 17, 2007 | 08:50 AM
sillypuddy's Avatar
67mm.. thanks!
67 millimeters = 2.63779528 inch
-joe
Old Feb 14, 2007 | 01:30 AM
blykins's Avatar
is the rear door speakers 67mm too? Also are the front and rears both 6.5"? The rear is just a midrange speaker am i correct? I just got my fit and trying to learn about it.
Old Feb 14, 2007 | 02:59 AM
Injundon's Avatar
Rear doors are huge since the rear window doesn't go down that low.
Old Feb 14, 2007 | 04:06 AM
vividjazz's Avatar
6.5" also at rear. Depth would be similar but haven't bothered to measure since rear speakers are only for rear passengers. With your front stage set correctly the the sound would appear to be surround anyway. If the rear dominated or was set to the same level as the front then it would be the same effect as going to a live concert and turning your back to the stage. The money saved on rear speakers and rear amplification can be put towards a better front stage resulting in better sound for the same dollars.
I still laugh every time someone gets into a SQ competition car and asks what they are running in the rear or is it 5.1 because the sound seems to be coming from all around. Always the same answer stock for fill or in a lot of cases absolutely nothing.
g33s0n6656
Dec 1, 2022 07:22 PM
jsr
Apr 25, 2011 01:21 AM
EMC2
Oct 27, 2010 03:19 PM
Fitpizzaz
Mar 19, 2009 09:13 PM
pvanberk
Aug 14, 2006 08:15 PM
