Battery Cable Replacement
Old Sep 9, 2025 | 07:07 PM
merthalum's Avatar
Hello all, I am very new here and new to being a Honda fit owner. I purchased it off my sister, who had a few problems with it, but overall it was still functional. I've been having a problem with a battery drain. If I leave the car sitting for a couple days, it won't start back up. I've had to recharge the battery several times, including replacing it entirely. I thought I had fixed the problem when I unhooked some faulty door-locking mechanisms, and I think that helped, but I'm still dealing with the problem. I think there may be a few things wrong, but I'm not sure what.
I've gotten advice from a mechanic I know who's taken a look at it to replace the battery cables, since they're looking pretty shabby and I can't seem to get a good connection, even after some good cleaning. However, taking a look inside the hood, this doesn't look like it'll be an easy job. I have two main questions:
1. Has anybody here replaced the battery cables on a 2009 Honda Fit and have any advise or knowledge on what that involves?
2. Does anybody have any guesses on what might be causing the battery drain?
(Additional information: I've already done a parasitic drain test but the multimeter showed normal amperage. Not sure where to go from there.)
Old Sep 10, 2025 | 08:01 PM
Tkonrr's Avatar
Two common sources of parasitic battery drain with Honda Fits- The a/c clutch RELAY. It is located under the hood/ engine compartment, behind the left/ driver side headlight inside a small plastic enclosure. A bit difficult to locate but a relatively easy/ inexpensive fix- new relay. The second source is the number 1 circuit, the fuse in the upper left of the fuse panel inside the car, to the left of where your left foot rests under the dash while driving. I was not able to pinpoint the exact source of the drain so I simply attached a fused switch on the dash to cut off power to that circuit when the car gets parked.
Old Sep 13, 2025 | 09:35 AM
woof's Avatar
There are a number of videos on YouTube showing how to track these down. You have to hook up a meter and then check it for hours after the engine has been turned off because the drain may not start until some time after. Once you've confirmed a drain you need to check the individual fuse circuits one by one to identify which one is responsible. This is a long drawn tiresome process. Most shops don't want to do it because of this. I watched one video where they traced the problem to the power steering system. Probably a bad circuit board inside it but not serviceable so they had to replace the whole thing,
You should begin by making sure there is no add-on accessories on the car, no modifications, nothing plugged into the USB ports etc. No camera hooked up.
Calvincito
Dec 20, 2024 01:16 AM
sittinhawk
Jul 12, 2024 09:11 AM
rshimizu12
Feb 18, 2024 06:17 AM
pzriddle
Jan 23, 2015 06:31 PM
CarTwins
Aug 22, 2012 11:26 PM
