Exactly which oil for 2019 Honda Fit EX?
Old Apr 28, 2026 | 03:29 AM
airman23's Avatar
I live in Los Angeles. I brought a 2019 Honda Fit EX from Carmax last year. it came due for an oil change, no big deal I thought as I've been getting my cars oil changes for decades however this time was different in that the Honda Fit is the 1st car I've ever owned that requires full synthetic oil, all my other cars have used conventional oil. Synthetic oil cost more but as that's whats required I got it done at Pepboys. They used Pennzoil Platinum Premium Synthetic Oil OW-16.
Pennzoil Platinum® Full Synthetic Motor Oil | Pennzoil®
On page 501 of the owners manual it says this
Genuine Honda Motor Oil
• Premium-grade 0W-16, 0W-20 detergent oil with an API Certification Seal on the
container.
However in doing some research there are those who day the 0W-16 AND 0W-20 weight is too thin and may not protect the engine as 5W-30. 0W-16/20 is supposed to be for better gas milage but I'm more concerned about protecting the engine from weat and tear. I'm confused so I'm putting it out there. JUST exactly what grade oil to use for a 2019 Honda Fit EX that is best for the engine?
Old Apr 28, 2026 | 05:00 AM
Chitown Fit's Avatar
Oil Grade.
What oil grade is printed on the oil cap?
Old Apr 28, 2026 | 09:26 AM
woof's Avatar
Good answer!
I've always used 0W20 (and usually Pennzoil Platinum at that). The best comment that I've seen online in the "which grade" arguments is that the grade you choose isn't as important as the frequency of oil changes which should be every 5000 miles.
Old Apr 28, 2026 | 12:29 PM
SilverEX15's Avatar
"it came due for an oil change" Of course it did! Why would they spend $20 if they can get by without spending it. 🤣
We've put over 100,000 miles on two Fits - 2015 and 2020 - using synthetic 0W-20. No problems. Many people say that Honda recommends 0W just to get good mileage. I really don't mind getting good mileage. 😁 If 0W-20 was destroying engines, I think there would be lots of factual evidence about that.
Old Apr 28, 2026 | 12:59 PM
Mister Coffee's Avatar
@airman23 Where does it say use only fully synthetic? Why would you use anything other than what the OEM recommends?
I use Amsoil Signature Series, which is fully synthetic like Pennzoil Platinum, and I use the weight that is recommended in my Owner's Manual, which is 0W20 for the 2nd Gen.
Old Apr 28, 2026 | 05:47 PM
Steve-o's Avatar
I have a 2017 but it's the same engine afaik. Here's the page in my owner's manual. Note that you may use synthetic; it's not required. I run synth because it gets darned cold here in the winter. But that's where I live.
Owners manual page specifying oil
Owner's manual page specifying oil
Old Apr 28, 2026 | 07:00 PM
woof's Avatar
I don't know what the current situation is but the last time I checked a few years ago 0W20 was only available in synthetic.
Old Yesterday | 01:53 AM
fibrepunk's Avatar
All 0W-20 motor oil are synthetic. And most of the OW-20 oil are full synthetic, but if you are willing to go out of your way, you can find some 0W-20 synthetic blend, listed below.
1. Motorcraft SAE 0W-20 Synthetic Blend - Look at the product details.
2. Valvoline MaxLife High Mileage 0W-20 Synthetic Blend
3. AMSOIL 0W-20 Synthetic-Blend
4. Honda Genuine 0W-20 Synthetic Blend
5. Castrol GTX Ultraclean 0W-20
Old Yesterday | 06:51 AM
SilverEX15's Avatar
All I've ever used is synthetic 0W-20. If it's a blend, how much of it is synthetic? A spoonful? I don't know if we can trust "synthetic" to be synthetic, but that's what I use.
Old Yesterday | 05:19 PM
t-rd's Avatar
Honestly the benefits of using full synthetic oil outweighs the small amount of money you save by using conventional. But if you'd like to buy conventional and try it on this engine then go right ahead. Open up the valve cover in 5 years and see the result for yourself.
Old Yesterday | 05:39 PM
fibrepunk's Avatar
Well, even when they claim full synthetic, is not "truly" synthetic, just look up Mobil 1 vs. Castro lawsuit in 1999 over "synthetic" If you really care for the history on synthetic motor oil.
Sources:
1.
2. AMSOIL's
3. These are the "true" synthetic motor oil you can find in the market today:
a. Amsoil Signature Series
b. Red Line
c. Motul 300V
d. Ravenol
e. Mobil 1 Extended Performance and Mobil 1 ESP
Anyway, I am fine with just using Kirkland's synthetic motor oil from Costco.
Old Today | 07:54 PM
OliveOil's Avatar
Any 0w-20 will do. Find the least expensive if that makes you happy. It won’t matter to your fit. Oh, and use the computer to tell you when you should change oil.
Old Today | 09:03 PM
Agreed.
$57.24 for my oil change at my new Honda Dealer.
I follow the oil change computer monitor.
I change my oil when it's 30%.
Breezer
Nov 11, 2025 12:58 PM
Ummitsgabe
Mar 14, 2021 11:22 AM
SevereService
Dec 1, 2011 09:13 AM
hondafit_03
Aug 13, 2011 11:05 PM
hungff77
Oct 3, 2010 04:27 AM
