seat track extenders
Old Feb 20, 2007 | 12:40 PM
dan-bou's Avatar
Hi everybody!
Do you know if somebody have made this modification for the driver seat?
I want have more confortable position for long drive.I'm tall, 6'3" and when i purchase my fit sport, i dont make a long drive test. Now It's a problem for me, I'm not reelly confortable for a long drive and i want keep my FIT for long time.
Does anybody have same problem of me?
Do you have picture for this modification?
Thank's
Dan-bou
Old Feb 20, 2007 | 02:38 PM
htewam's Avatar
I'm 6' 2" but not particularly "leggy". I did look into seat mods but didn't find anything that seemed reasonable without changing out the entire seat. You might, however, spend some time deciding what is the real problem for you on long drives. For me, the seat position seems less an issue then foot fatigue... the gas pedal is so "light" that my foot & ankle gets sore trying to hold my foot up off the gas. One of the folks here actually jammed some foam (carpet backing) under the pedal to improve the stiffness although it would be nice to find a more elegant approach. I also raised the rear-view mirror a bit because it typically was sitting directly in my line of vision out the front windshield. I also installed the Zeta dead-pedal so that my left foot has a place to rest.
The things we will do to make a small car fit a big driver :-)
Old May 22, 2007 | 01:58 PM
gcubed's Avatar
i fit ok in the fit, as well as any other car, but if you can get rail extensions, that would be ideal, i dont want to lose the magic seat ability, so i dont want to slide my rails back. (you can talk to some mechanics and/or dealers, they will move your seat rails back a few inches for you, although it does pose a small saftey concern, as the airbags are all calibrated for the stock positioning)
Old May 22, 2007 | 02:32 PM
dan-bou's Avatar
I have do my modification on that.Home made modification. Dont ask for any picture, it's my responsability for that because the seat it 2 inch more up and 3 inch more back. I never cut the original track, because if someone in the futur want purchase my car, it's very easy to replace in original position.By the way, i can use the magic seat if i place my driver seat enough in foward position without any poblem.
NOW i like not i LOVE drive my car. I'm confortable for long distance, my children have enough place behind me.
The only problem now is FUEL consume, nothing better under 6 liter per 100 kilometer.
Old Oct 29, 2007 | 11:22 PM
no user name's Avatar
i'm interested to know how you did the seat extension mod..... appreciate any tips and pointers.... thxs
Old Nov 3, 2007 | 04:54 PM
wrx112's Avatar
I would like to know too please.
Old Jun 30, 2008 | 11:50 AM
itsmeb*tches's Avatar
I would like to know as well, I have noticed my leg and ankle are sore about a 2.5 hour drive in the car.
Help is needed for us tall guys.
Old Jun 30, 2008 | 01:26 PM
GD3-Fit's Avatar
I <3 SPOON
he wants to get his gangster lean on in the Fit
LMAO!
j/k guys
-Ricky
Old Jun 30, 2008 | 01:52 PM
Thats not the problem, I can gansta lean all I want, but my damn ankles hurt.
Old Jul 15, 2008 | 07:06 AM
dacollier1's Avatar
moving seat back 1-2" more
I should have taken pictures, but didn't think about it. it's as easy as drilling 4 holes to get an extra inch and a half travel.
Flip the seat upside down and look at the track. You will see dimples in the seat rail that acts as a stop for the slider/track. Each track has 2 stops that keep it from going backwards, and 2 more that keep it from going forwards too far. What you are going to do is remove the two that stop the seat from going backwards (2 per rail, which is 4 per seat). Since there are 2 dimples pretty close together in the middle of teh track, you will see the front one of teh two prevents the seat from going backwards, and the rear of the two keeps it from going forwards. You are going to remove the first one which means the second will now be rearward stop adding about 1.5" of rearward travel. the one dimple left will act as both the forward and rearward stop when you are done. But there is also a second rearward stop at the back of teh track that also needs to be removed. Do that one first because you can get to both sides and you will be able to catch the drill chips and see that the dimple you are going to drill out will come out as a larger peice.
Move the seat all the way forward on the track so the tracks sticks out the back and you can see both sides of the rear most dimple. Drill out the dimble with a 5/16" drill, then go back and drill it again with a 3/8". If you do it all in one pass with a 3/8" the center of the dimple will come out in one peice and fold under the track making it harder to get out. Try it on the dimple you can get at from both sides first. Then do the dimple you can't get at from both sides (i.e. the forward one near the middle of the track). Also, the 5/16" drill will leave a bits you can get out of the track from a hole in the side when you do the forward one. I use a vacuum while drilling, and grease the drill bit to hold the metal chips.
There is a steel roller that hits the dimples to stop the seat travel. it's very tight clearance. once you drill the two stops out on a slide, it will be hard to get the slide to pass the drill holes, but light persuasion the first couple passes will flatten any raised edge around teh drill hole and it will then slide just as well as anywhere else in the range, but go back close to 1.5" further than it did before. Even the locks in the track continue past where the track goes today.
Old Jul 15, 2008 | 09:18 AM
solbrothers's Avatar
i am 6'6" and i dont have an issue. i was thiknking of modifying the brackets, but wont that mess up the magic seats functionality?
Old Jul 16, 2008 | 12:26 AM
Do you have any pictures at all?
Old Jul 18, 2008 | 06:44 AM
dacollier1's Avatar
I think I took one picture when I had the seat entirely torn apart during the investigative stage, maybe even before I figured it out. I made it far more complicated than it needed to be. Once I figured it out, it was done and back together in no time. I'll see if I can find that picture and load it to photobucket.
Old Jul 18, 2008 | 11:13 AM
Thank you for your help.
Old Jul 21, 2008 | 07:17 AM
dacollier1's Avatar
I did take one photo for where to drill to extend the tracks. You do not need to take apart the seat to do this even though the photo shows only the frame. On the right side you can see two white circles around dimples, and those are the ones to drill out. On the left side the flash obscures the ciricles, but hilights the dimples better. Use a new drill bit to avoid a ridge on the inside of the hole. the magic seat functionaility still works with this, but you may have to move the seat up just a tad. The next thing I did after this, was to fit a MINI Cooper seat, and that did mess with the magic seat functionaility because the track stuck back too far, but I'll get around that somehow.
Old Aug 18, 2008 | 10:17 AM
Rannous's Avatar
I did the drillout of the rail dimples, and have good and bad news. It worked just like you said, the seat goes back an extra 1 1/2 inches on the first try, smooth and no problems. However, it won't lock back there - I had to do a sudden stop this morning on the way to work and it jumped forward to the old seat position and clicked into lock there! Did I miss something to get it to lock at the full new back position?
Thanks in advance...
Rannous
Old Aug 25, 2008 | 08:21 AM
dacollier1's Avatar
I haven't had that experience, but this weekend I put the stock seat back in, and yesterday got in the back seat and forcebly pushed the front seat forward. It did move up, but not far before the seat caught and locked in place, but still back from the stock location by more than half the distance gained by drilling out the dimples. So safely, i guess this buys about 3/4 to 1 inch, or pin the seat in place (like a roll pin or hardened steel pin....smaller but similar in concept to a hood pin so it could be removed easily for short drivers to move the seat up.
I'm working on getting the Mini Cooper seat sorted out now. Had that in and out a couple times, but haven't totally sorted out the air bag light... got the side air bag sorted with a 2.2 ohm 2 watt resistor in the plug, but the seat location sensor hasn't yet been overcome, even after installing it on the Mini seat in what I think is the proper location and orientation, and pluging it back in.
Old Dec 1, 2008 | 07:33 PM
xJGBx JayNutz's Avatar
awesome now if only we could get rid of the active headrest !!!
Old Apr 22, 2009 | 11:15 PM
COMPAQ0924's Avatar
What's wrong with the headrest? And what makes it active? seems pretty normal 2 me?
Old Sep 25, 2010 | 09:18 PM
feddup's Avatar
Thank you!
Many thanks to Decalleir1 for his DIY seat travel mod! I just completed it and the difference in comfort is remarkable and the price was right ($8 for two cotterless hitch pins). I did drill an additional 1/4 inch hole in each track parallel to the floor to hold the seat in the rearmost position. The cotterless hitch pins can be removed from behind the seat in seconds to accommodate shorter drivers or to regain the magic seat's flexibility. It took two hours because I was being VERY careful not to mess this up. Next I'm going to install the inflatable lumbar support
MossMotors.com - Restoration Parts And Accessories For British Cars
that I ordered. I hope that goes as smoothly!
