Re: 2005 Accord ... Should I?
Guest
Posts: n/a
Early pad wear is a result of the TCS, turn it off and you will find that
the pads last longer and the car performs better.
<jmattis@attglobal.net> wrote in message
news:1107368261.788017.236400@l41g2000cwc.googlegr oups.com...
> DaveR wrote:
>> My lease is nearly up on my 2002 Accord. I've been leasing accords
> for
>> 8 years now. But this last one had some issues ... it needed a new
>> transmission (and even the new one is showing some early symptoms of
>> trouble). The brakes also wore down at about 25K, earlier than any
>> other Accord I have owned (though I can't be sure it wasn't my
>> driving).
>> I've been a loyal Accord driver for many years ... any reason not to
>> consider the 2005 model? Has Honda finally fixed the Accord
>> transmission problems?
> The early pad wear (on the rears) is a common complaint with the
> current model, but partially is determined by driver habits. On the
> other hand, it's easy to fix and the dealer has to make money from
> something. Just another small part of car ownership. I had an '90
> Integra that made it 105,000 miles on all the original pads, though.
> Nice. My gf (now wife) also had a '90 Integra, but she burned through
> pads every 30,000.
> They've probably got the tranny problem licked too. Reportedly the
> 2006 mid-model change will revise quite a bit of the exterior -- that
> would dampen my interest somewhat, but if your lease is up, ya gotta do
> something regardless.
> JM
> for
>> driving).
> pads every 30,000.
> JM
Guest
Posts: n/a
How do you turn it off? It seems TCS comes on automatically when
needed, i.e. when the car is skidding.
I have on occasion turned it on manually when driving in slippery
conditions, but otherwise I let the car deal with it.
Guest
Posts: n/a
"DaveR" <NOSPAM_drubin@NOSPAM_i-2000.com> wrote in message
news:W6UDQrPwLd6dCQ16BDd6TeP1exOJ@4ax.com...
The TCS button turns it off.
Guest
Posts: n/a
On Fri, 04 Feb 2005 16:40:47 GMT, "Seth"
When I press the TCS button the dashboard light comes on. So I assume
TCS is OFF by default.
The only other time the TCS dashboard light comes on is when I'm
skidding.
skidding.
Guest
Posts: n/a
news:JKYDQmDxRgkTrutxvn=g85fhHQD+@4ax.com...
>>>>that
It's on by default. The light is a reminder that it is disabled.
> skidding.
The flashing TCS light means it is actively working on an issue (skidding).
Have you look in the manual? It is clearly spelled out.
>>>>that
> skidding.
edmacatack
May 4, 2005 11:16 AM
