97 Honda Accord seatbelt retraction problem
Old May 4, 2005 | 11:16 AM
techman41973@yahoo.com
Guest
Posts: n/a
I have a 1997 Honda Accord with about 140K miles.
The seat belt on the drivers side doesnt retract well anymore.
Often the belt gets caught in the door when I leave the car.
Perhaps this is normal wear and tear on the seat belt mechanism after
so many miles. Just wondering if anyone has a similar problem and if
anyone tried to repair this, roughly how much should it cost?
Thanks
klijam64@email.pct.edu
Guest
Posts: n/a
Re: 97 Honda Accord seatbelt retraction problem
Hi. Will the belt go to the end of the track if you help it along?
Sounds like it may just need a good lubrication, either of the
track/slider, or the drive mechanism.
motsco_ _
Guest
Posts: n/a
> Thanks
Read your (American?) owner's manual very carefully. . . You have
specific rights that apply to the seat belt mechanism.
'Curly'
radar
Guest
Posts: n/a
often seat belts get worn and ever so slightly frayed becoming slightly
'furry' which makes them reluctant to retract ( especially drivers belt ) so
if you seat belt seems slightly furry or fluffy then shave it (carefully!)
whith a bic or similar disposable razor. This should help!
<techman41973@yahoo.com> wrote in message
news:1107635464.688647.186850@l41g2000cwc.googlegr oups.com...
> Thanks
Guest
Posts: n/a
Oh I misunderstood the original posters question...I thought he/she
meant the motorized retraction.
-Jamie
ravelation
Guest
Posts: n/a
"motsco_ _"@interbaun.com (motsco_ _)
>mechanism.
I've often read in differing ngs that broken seatbelts will always be
warrantied by the dealer, no matter the age of the vehicle. True? The
reason I ask is we just bought an '01 Infiniti QX4 and it has a seatbelt
that won't come out of the retractor. We signed the 'as is' clause, but
I'm hoping a broken seatbelt would be something they'll honor with no
quibbles or charge for the service.
Timothy J. Lee
Guest
Posts: n/a
In article <4653-42078F26-168@storefull-3276.bay.webtv.net>,
Read the owner's manual for the vehicle regarding warranties that apply
to it.
Timothy J. Lee
Unsolicited bulk or commercial email is not welcome.
No warranty of any kind is provided with this message.
ernests131@charter.net
Guest
Posts: n/a
> Thanks
I have had that same problem with the belt on my 94 civic.
If the Accord has the same type belt as the Civic this may
fix it. I took the cover from over the belt (heavy plastic that
can be pryed off) and found the belt twisted just above the
retracter. Work the twist up to the top hanger, slide the half
fold to either side of the hanger and then pull the fold through
the hanger, this will be a bit of a pull to get it through.
You may have a few turns in the belt at the floor mount but they
can be removed by turning the belt hanger around the mounting
bolt near the floor. My belt now retracts smoothly.
Ernie
J.
Guest
Posts: n/a
You might also try cleaning the belt (soap & water only, then dried well)
and also the guide on the pillar that the belt slides over. This was
actually a service bulletin on my old 90 Prelude and completely cured my
slow/hesitant retracting belt when I tried it when the car was about 7 years
old.
I could actually see crud on that belt guide and also used a thin stiff
plastic sheet to help scrape it off. Don't know if Honda has changed
materials or spacing to help alleviate that problem.
J.
<ernests131@charter.net> wrote in message
news:1108077552.897571.164100@g14g2000cwa.googlegr oups.com...
> > Thanks
> Ernie
User1
Oct 23, 2017 09:26 PM
Telix
Oct 5, 2007 02:34 PM
Ray
Aug 10, 2005 08:36 PM
Matt
May 4, 2005 04:44 PM
PK
May 4, 2005 11:16 AM
