How to adjust Fog light?
Old Mar 14, 2007 | 11:39 PM
bestfit's Avatar
i do lots of night driving and i noticed i can barely "see" my passenger side fog light beam.. i mean it is "on" but since i am left side of vehicle i can,t see the beam pattern at all. i wish if i could raise it bit higher to illuminate the road better.
i think i have to adjust something inside fogs.. can someone direct me here?
Thanks in advance.
Old Mar 15, 2007 | 12:54 AM
Fit of RAGE's Avatar
there's a little screw behind the foglight assy. Just take out the light housings and turn it one way or another and see with way is up. I think it's controlled my either a 10mm or a phillips head
Old Mar 15, 2007 | 05:21 PM
bestfit's Avatar
Thank You.. i will try that...
Old Mar 15, 2007 | 08:57 PM
wyy183's Avatar
You do not have to take anything out. You will need a long (6"?) phillips-head screwdriver. It is difficult to see, and describe, but there is an adjustment screw on the back of the fog light that is accessible through a hole, underneath the front of the car. Tighten the screw to raise the light beam, loosen to lower the light beam.
Old Mar 15, 2007 | 10:29 PM
bestfit's Avatar
Thanks.. i will look under the front bumper first
Old Jul 25, 2009 | 01:25 AM
RichXKU's Avatar
Unless wyy183 has a magic screwdriver I didn't see any way of adjusting from underneath.
But it's so easy to just remove 1 screw and the plug and do it that way, that's what I did.
Fogs are now up to just below the low beam.
Old Jul 25, 2009 | 01:31 AM
xonexlifex's Avatar
Ya its way easier to just take the foglight housing out to adjust the screw. Just like the other guy said its kinda hard to get to the screw if u dont have a special screw driver. But even if u did have one trust me its easier to just take it out.
Aznsupastar
Sep 6, 2018 10:12 PM
2007Fit5AT
Jul 27, 2013 05:58 PM
dman
Oct 12, 2009 10:36 PM
Sugarphreak
Sep 26, 2007 10:37 AM
fitfit123
Feb 3, 2007 05:13 PM
