whats wrong?
Old May 4, 2005 | 11:16 AM
gabriel
Guest
Posts: n/a
whats wrong?
can anyone tell me whats wrong with my car? i have a 1998 honda civic lx
32,000 miles. whenever i stop i feel some slight vibration and some noise
in front, sometimes the car vibrates so hard. Is this normal for a car? or
is there something wrong? By the way i just have an oil change 2 weeks ago.
Remco
Guest
Posts: n/a
Re: whats wrong?
Any noise coming along with this vibration? Like a scraping noise?
Bror Jace
Guest
Posts: n/a
Re: whats wrong?
Sounds like possibly a warped brake rotor.
This can be cause by uneven wheel lug nut tightening.
--- Bror Jace
soydios@gmail.com
Guest
Posts: n/a
Re: whats wrong?
It sounds like a problem with the time belt. Have it checked, cause if
it fails it's going to cost you a lot to fix your car.
gabriel
Guest
Posts: n/a
Re: whats wrong?
yes sometimes, i'm not sure but could it be the timing belt causing that
noise?
gabriel
Guest
Posts: n/a
Re: whats wrong?
that's what i'm thinking, the timing belt?
Remco
Guest
Posts: n/a
Re: whats wrong?
Before checking the belt, I'd check the rotors, as Bror below already
mentions.
If the problem was within the belt, one would imagine that you'd hear
the noise at other times as well - they tend to be noisy when cold, for
instance. I wouldn't excluded it but I'd check anything related to the
brakes first.
Sportster4Eva
Guest
Posts: n/a
Re: whats wrong?
I had the same thing happen to me before, not a Honda, but another
popular front wheel drive import. Turns out it was the front wheel
bearings were getting loose, causing a wicked shudder while braking,
especially coming off the highway onto an offramp.
Jack it up and rock the wheel from the top and bottom. Any play could
indicate worn suspension parts.
Paul
'91 XL1200 '77 GL1000 (W.I.P.)
"I'm the one that's got to die when it's time for me to die, so let me
live my life, the way I want to." Hendrix
07FitSprt
Feb 24, 2019 09:06 PM
mnapuran
Jun 11, 2016 06:00 PM
apexanimal
Nov 9, 2013 08:11 PM
myfitfreakacct
Aug 10, 2011 01:51 PM
TMATHEWSON1008
Jan 10, 2008 08:50 PM
