Synthetic Oil and mileage....
Old Apr 3, 2007 | 02:23 AM
Tomwaits's Avatar
Question Synthetic Oil and mileage....
Hi all, wondering if anyone has been running synthetic oil, and perhaps Royal Purple. I'm closing in on my first oil change, right now at 4400 miles. Been getting 32 mpg, with about 90% city driving.
I have heard that certain synthetics can boost mpg, but wondering if anyone has tried it in the Fit. Love the car, btw.
Regards
Old Apr 3, 2007 | 02:53 AM
George02's Avatar
the car will love royal purple. I kno my s2000 did. that's wat I plan on using. that's all I use to put in my car
Old Apr 3, 2007 | 08:14 AM
fithouston's Avatar
currently i'm using royal purple the fit loves it i have also used it in my past 2 toyotas. Also i got a chance to visit royal purlpe and see first hand how great of a product they make. It really holds up and can prolong your oil change interval. My past 2000 solara i went every 7-9k miles before changing and the oil would still be pretty clean i highly recommend royal purple
Old Apr 3, 2007 | 09:02 AM
Fit of RAGE's Avatar
RoyalPurple is good, i like MObil1 more but it's also more expensive. I woudl recommend NOT changing to FULL synthetic untill you get past approx. 10,000KM (roughly...8500miles????)
Old Apr 4, 2007 | 01:33 AM
Tomwaits's Avatar
Smile Thanks guys!
Thanks for the replies! I have heard that you should really let the motor break in before switching to synthetics so I'll probably wait until after the first oil change.
Have you guys seen any improvement in mileage and have you switched to the royal purple tranny fluid?
Thanks again!
Old Apr 4, 2007 | 05:11 AM
fithouston's Avatar
haven't switched to the tranny fluid yet, but plan on doing it on my next oil change (est. 14k miles)
Old Apr 4, 2007 | 10:39 AM
peeker's Avatar
what is honda's policy on synthetic oil changes as it pertains to the car's warranty?
let me clarify: some car companies still demand that the car get the oil changes at the required intervals, regardless if the car is running synthetic.
this would make running synthetic quite a bit more expensive (unless you do the changes yourself)
Old Apr 4, 2007 | 12:03 PM
milano sol's Avatar
i am a believer in synthetic's.....the Oil Life meter on the Fit WILL NOT take into consideration that you are running a longer life oil such as a full synthetic but your motor will be better lubricated in between intervals and you can probably run it down to 15% every time before changes. im about to change over to synthetic this weekend (did first 2 with normal oil)
im actually using Castrol Syntec (i too loved Royal Purple in my Miata's but castrol is just easier to come by and cheaper at wal-mart) and ive ran castrol in all my hondas and cant complain
good luck with the royal purple. you wont be dissapointed.
Old Apr 15, 2007 | 06:21 PM
Jackal's Avatar
i'm getting about 30 mpg using royal purple. i drive with a heavy foot. On the bottle it says it last up to 12k miles so i gues when oil life on the fit says 15 or whatever percent you usually change your oil in, just reset the oil meter.
Old Apr 24, 2007 | 10:39 AM
jkandell's Avatar
just reset...?
Won't that ruin the timing on all the other "maintenance minder" items?
Old Apr 24, 2007 | 03:13 PM
milano sol's Avatar
why would it hurt the other minders? the owners manual states to do an oil change at 15% anways....or 12 months. when you reset it itll post the letter/number combo you need to do in terms of maintenance. the longer you wait the more youll have to do thats all.....
rotate tires, filter, check hoses and fluids....thats usually all it is anyways just a check and fill deal (dont know why honda charges 200+ to CHECK and TOP OFF!!!) but yeah. nothing big.
Old Mar 31, 2008 | 02:06 AM
b4db0y's Avatar
What do you mean by full synthetic?
I am at 20% for the oil change indicator @ over 8000 km. I am getting its first oil change soon, maybe when it goes down to 15%. Which motor oil is good for the Fit? I am going back to the dealer to get the oil change, so I don't know which motor oil they will use, or should I buy my own?
Old Mar 31, 2008 | 07:45 PM
doctordoom's Avatar
Supervillain
some synthetic oils are part synthetic, and others are "full synthetic"
any motor oil is good really, as long as it is SAE certified (or whatever it was called). what's more important than brand of oil/fluids is the frequency with which you change it. and what's more important than the quality of the oil, is the weight/specifications of it. but i use royal purple because it makes me feel good haha.
Old Mar 31, 2008 | 09:04 PM
after the first free oil change at the dealer, im going to run Mobil1 silver
cap on mine with the factory filter/washer.
i hear the latest M1's are no longer true synthetics...but it'll work for
me.
ZXRider
30
Jun 24, 2023 06:36 PM
Black01
Oct 25, 2010 04:45 PM
dman
Jan 23, 2010 11:09 PM
912
Nov 21, 2009 09:46 PM
mattftl
May 25, 2008 07:38 PM
