A few questions~
Old Apr 10, 2007 | 08:46 PM
Mattaru's Avatar
A few questions~
Ok so my friend has a 12" subwoofer and amp ready for me, and I picked my Honda Jazz up this afternoon!
Forgive me for being a complete noob. However . . . I'm told that I have to take my current headunit out and replace it with a new one in order to take advantage of my sub.
That, or buy a converter, which I don't have a clue about, and any detrimental affects it has upon the car But this enables me to keep my stock headunit right?
Apparantly the converter doesn't come cheap. It would also mess my headunit up =S? Anyone have any idea? I had a look at the sticky thread but there wasn't much there that could answer my basic questions.
HONDA JAZZ/FIT ACCESSORIES
Also, under here on page 4, there's a "Honda Subwoofer" which looks quite interesting. Does anyone have one or know anyone who has one?
How poweful is it? How does it connect to the headunit
Subwoofer
Measuring only 16cm in diameter and 4cm in height this highperformance
subwoofer combines remarkable compactness
with amazing 120W maximum power and extremely low
current consumption. Its secret lies in its innovative
Neodymium magnet, ten times more powerful than that of
conventional speakers. In short, this Honda subwoofer boasts
power as well as quality.
Grateful if anyone could give us a hand here.
Pricing and how much a converter/honda sub would set me back would also be much appreciated!
Thanks! Matt
Old Apr 12, 2007 | 01:06 PM
Mattaru's Avatar
*Hopeful Bump*
Scrap the question about the Honda Subwoofer, that's a bit of a rip-off x.x
Old Apr 12, 2007 | 08:17 PM
BigBadMadMan's Avatar
You have the option of doing either. You can either replace the stock head unit to take advantage of things like in-dash navigation or video. That, or you can keep the stock head unit and just add a sub and amp. The most common way to add just a sub and amplifier is to tap into the signal going to one of the rear speakers by splicing into the speaker wires and running those to the amp. Either way it's somewhat of an involved process, but (if installed properly) neither should do any damage to your car or the wiring.
Old Apr 12, 2007 | 08:51 PM
joe d's Avatar
It depends on what kind of amp you have. If the amp has speaker line inputs, you just tap into a current speaker pair (or two) and run it directly to the amp. If it only has line level inputs, you need to buy a line out converter, tap into the speaker lines, run that to the converter, and then run rca cables from the converter to the amp. They're pretty cheap... like $25 US - whatever that means in quid.
You'll have to run a line for the power from your battery to the amp, and tap into the remote start line behind the headunit and run that to the amp too either way.
As said above, neither option will damage your system.
Old Apr 13, 2007 | 01:30 PM
Yea, I was meaning if it has speaker level inputs. I don't know why I neglected to add line level inputs into my answer, so thanks Joe D for clarifying. Also don't know why I completely forgot to mention tapping the remote start line.
The involved part is going to be running the power wire from the battery to the amp...being that you'll have to go through the firewall. Of course, splicing into the speaker wire or remote start wire would be pretty involved too if you don't know what you're doing...
Basically, have a shop do it for you...it's easier, less headache, and usually guaranteed. Besides, it's nice to just be able to pick it up, hop in, and go...not having to worry about how everything happened.
Old Apr 13, 2007 | 06:33 PM
Mattaru's Avatar
That's cleared everything up!
Thank you very much Joe and BBMM. Much appreciated =) I'll get the garage to fit this for me.
^_^ ~ Grací
milanojazz
Feb 23, 2011 11:09 PM
konespeed
26
Jul 23, 2010 05:21 PM
Wahe
Apr 14, 2010 09:36 AM
whoa42
17
Nov 15, 2009 07:21 PM
whoa42
Sep 4, 2009 09:56 PM
