2004 Accord
Old May 4, 2005 | 11:16 AM
steve barboro
Guest
Posts: n/a
2004 Accord
Has anyone had trouble with the front end banging on 04 Accord?
Isidoro Pulido
Guest
Posts: n/a
Re: 2004 Accord
What kind of banging? I have an '05 that has a weird "thump" noise coming
from the steering wheel when I reverse, then straighten out. It seems like
when I straighten out and drive forward, something sort of "thumps' into
place. I hear and feel it more prominently inside the cabin through my
steering wheel. I can barely hear something mechanical when I have my window
rolled down and the noise is re-created.
However, this only occurs during initial startup. It goes away after about
15 minutes worth of driving. I have to let my car sit for more than an hour
before the noise comes back. I have not had time to take it in to have it
checked. I plan to have it checked when I tale it in for the first 3500 mile
service (about 200 miles away).
Regards,
Isidoro 'Lolo' Pulido
"steve barboro" <sbarboro@mts.net> wrote in message
news:awKUd.25777$Ka6.182313@news1.mts.net...
motsco_ _
Guest
Posts: n/a
Re: 2004 Accord
Add two litres of oil and it will stop 'banging' :-) (not much to go on)
'Curly'
Bond 007
Guest
Posts: n/a
Re: 2004 Accord
Mine is in the front end when going over bumps. Sounds like loose ball
joint, or steering links. The car has very low mileage 5000 this is why I'm
asking if it's a normal sound.
Isidoro Pulido
Guest
Posts: n/a
Re: 2004 Accord
"Isidoro Pulido" <lolo@advantexmail.net> wrote in message
news:1127fv8jvdk3jb1@corp.supernews.com...
window
hour
mile
> Regards,
Took the Accord in to the dealer and had them inspect the "thump". They
indicated that it was probably due to the ABS system resetting/activating
itself. I didn't know that Hondas did this. My '02 Olds Intrigue did this
and the noise from the Honda is somewhat similar. However, they could not
reproduce the issue. In any case, they said that if the noise got worse to
bring it back in and have it checked again.
LoLoMaN
Timothy Kong
Guest
Posts: n/a
Re: 2004 Accord
Our O4 Accord made a banging sound when going over bumps. The dealer said
the right front strut had an internal leak. After they replaced it, the
noise went away and the car handles better. You should bring your car to
the dealer.
Tim
Bond 007 <sbarboro@mts.net> wrote:
: Mine is in the front end when going over bumps. Sounds like loose ball
: joint, or steering links. The car has very low mileage 5000 this is why I'm
: asking if it's a normal sound.
: "steve barboro" <sbarboro@mts.net> wrote in message
: news:awKUd.25777$Ka6.182313@news1.mts.net...
:> Has anyone had trouble with the front end banging on 04 Accord?
Imminent Vengeance
Guest
Posts: n/a
Re: 2004 Accord
> the dealer.
How could it be a strut? I am pretty sure that the current Accord has a
double-wishbone setup in front and back with shocks and coil springs, just
like past Accords.
Timothy Kong
Guest
Posts: n/a
Re: 2004 Accord
:> Our O4 Accord made a banging sound when going over bumps. The dealer said
:> the right front strut had an internal leak. After they replaced it, the
:> noise went away and the car handles better. You should bring your car to
:> the dealer.
: How could it be a strut? I am pretty sure that the current Accord has a
: double-wishbone setup in front and back with shocks and coil springs, just
: like past Accords.
The dealer said strut and that's what on the parts list on work order.
Tim
Thomas Hern
Guest
Posts: n/a
Re: 2004 Accord
In article <d0i5nv$t3i$1@skeeter.ucdavis.edu>, Timothy Kong
> :> the dealer.
> Tim
They aren't really struts, exactly, but they call them that anyway.
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
JeremyE
May 14, 2006 02:01 PM
honda man
Sep 30, 2005 07:30 PM
RandyB
Sep 17, 2005 08:30 PM
Grahame
Aug 26, 2005 01:47 PM
nashville53
May 4, 2005 04:44 PM
