does any one changed Speakers?
Old May 25, 2007 | 06:47 AM
lilcat's Avatar
I'd like to know what size are those. seem like a 5.5inch. can i make a 6.5 inch in it?
Old Jun 4, 2007 | 03:50 PM
Redheart's Avatar
The guys at Tweeter weren't able to get Focal 165A 6 1/2 into the front doors without impeding window. I got 5 1/4 JL components instead.
Don't know if the Focals were just big for 6 /12 or if the door really is made for 5 1/4's instead.
Old Jun 5, 2007 | 12:09 AM
phatclient's Avatar
I got the polk db651 in front and back doors of
my base model fit, they are 6.5 inch but not super deep,
they didnt have any trouble installing.
Waiting on the scosche kit to install new head unit,
but these speakers are great improvement - at least 100% better,
they are very efficient, so louder, with lower bass and higher treble
even with factory stereo. Great for a small budget.
I wonder if you can get better speakers for about a hundred a pair?
peace
Old Jun 5, 2007 | 02:28 AM
koolkevin1107's Avatar
yeah i got new speakers on all 4 doors. I used Pioneer Premier TS-A631P 6.5" speakers in all 4 doors. The stock speakers are built into the bracket so i cut out the stock speaker from the basket then installed the new speakers into the bracket then clipped the stock speaker bracket back into the door so i didn't put hooles in my door panels.
Old Jun 5, 2007 | 09:12 AM
Redheart's Avatar
Kevin I have a question for you about the rear
speakers. I'd like to put them in myself-unlike the 5.25 JL components that I had Tweeter install. Could you explain what I would need to do in order to install a pair of 6.5 Alpine Coax speakers in the rear. I didn't quite follow you when you said you clipped the stock speaker bracket back into the door. Crutchfield said they would include speaker brackets with the Alpines. I'm a complete novice as you can probably tell.
I've got a 10" JL Subwoofer in the rear powered by an Alpine Mono Amp,
a Pioneer 5900ib head unit and an Alpine 4 channel Amp along with the a set of 5.25 JL Audio components in the front doors.
Thanks for your time,
Gregg
Old Jun 5, 2007 | 09:57 AM
Redheart's Avatar
Kevin-I found a more detailed account you gave
about your install in another thread so I'm good.
Thanks,
Gregg
Old Jun 12, 2007 | 07:22 AM
lilcat's Avatar
does any one install a infinity perfect 6.5" components speaks? any problem with install?
Old Jun 12, 2007 | 08:57 AM
CuTeBoi's Avatar
check depth, and be sure you use spacers when installing aftermarket speakers...
i've seen lots of other members speakers and they all seem to have 1" metra spacers installed.
Old Jul 1, 2007 | 01:56 PM
timot_one's Avatar
You should be able to get anything to fit with enough time, money, and skill. I'm pretty sure that most 6.5" speakers will fit with the correct spacer though.
Old Jul 1, 2007 | 02:56 PM
arteitle's Avatar
As I just posted in a different thread, there is an aftermarket speaker bracket available that fits the front and rear doors on the Fit, and provided enough depth for me to install Polk db6500s without impinging on the window glass. The Scosche SAHR6, meant for the Ridgeline, fits the mounting holes of the Fit's door. Note, however, that you still have to drill holes in the sheet metal and screw the bracket down. I also had to trim the plastic ring that surrounds the speaker on the inside of the door skin, so that my thicker, larger diameter replacement would fit.
Old Jul 2, 2007 | 01:14 AM
CuTeBoi's Avatar
Those look really good, much better than the ones i got from metra, but then again, the metra are universal, i passed the screws through where the brackets would catch, and i put backplanes behind to grab on to, no holes were made. =D
GotFitB13
Sep 22, 2016 10:41 AM
Tom Spahr
Sep 22, 2015 08:30 AM
polokid69
Jan 15, 2013 04:52 PM
EMC2
Oct 28, 2010 06:05 AM
baaba2007
Mar 14, 2007 02:31 AM
