Civic 01 LX Heater Issue
Old May 4, 2005 | 11:16 AM
HaroldWho
Guest
Posts: n/a
The floor vents seem to be dead for heating or A/C. Just a whisper of air
regardless of fan speed. Dash vents are fine. Same problem whether outside
air is on or off.
What should I be checking?
TIA,
HaroldWho
Powered by SuSE Linux 9.0 -- Kernel 2.6.9
News Reader slrn 0.9.8.1
motsco_ _
Guest
Posts: n/a
Re: Civic 01 LX Heater Issue
> air is on or off.
> TIA,
> HaroldWho
If the Civic has a changeable cabin filter, you may be able to boost
your airflow by about 300 % just by putting in a fresh filter. Works on
the older CR-V...If you close the dials on the dash vents, does the
downward flow increase? Have you looked under the dash to see what's
happening when you select various heater settings? Drop the glove box to
get a better look at lots of stuff. Try google too.
'Curly'
wasserball
Dec 28, 2017 01:02 PM
vonBobo
Aug 22, 2016 09:37 PM
AdamButlerTV
Jul 29, 2015 06:06 PM
arkansasfit
May 14, 2014 03:27 PM
Sherpa
Sep 2, 2010 03:48 PM
