Oil Temo high even after the cooler !!!
Old Jun 12, 2007 | 08:04 AM
kimo's Avatar
I have just installed B&M oil cooler in my car. Today I took the car for a ride and found out at normal driving it will hit 212, and if I drive like hard for 2 minutes it will hit 248 and the red light on my oil temp gauge will flash. How come that the temp raises if I have cooler, is that because I have normal engine oil. 80% of the cooler is installed behind the low down where ther is opening at the bumper where it can get more airflow. I was thinking maybe because I have small hole grill infront of the bumper to protect the AC and radiator from rocks, that it restrict the air flow, or because the remain 20% of the cooler is behind the bumper and doesn't reach any air.
Old Jun 12, 2007 | 01:17 PM
daviddahlb's Avatar
pics request
You can test if the air flow is the problem pretty easily with a hacked together air duct just to test it.
I'd like to see some pictures though if you can.
Old Jun 12, 2007 | 02:00 PM
805FitSport's Avatar
why are you soo concerned with oil temps... oil cooler is overkill on a fit.
Old Jun 12, 2007 | 05:37 PM
kimo's Avatar
I just install it because we have very hot weather back here.
Old Jun 13, 2007 | 08:40 AM
sortanewinatl's Avatar
if you didn't get an oil temp light before and you do get the light after the install, I would suspect something is installed wrong...
Old Jun 13, 2007 | 08:46 AM
kimo's Avatar
The install is right. The red light is from aftermarket oil temp gauge. The install is plug and play.
Old Jun 13, 2007 | 08:49 AM
sonicsc1's Avatar
what temp is the after market senser set for? maybe faulty
Old Jun 13, 2007 | 08:54 AM
kimo's Avatar
What do you mean by set.
Vince_TB
Apr 25, 2014 11:58 AM
Vash
Nov 3, 2011 06:52 PM
Kwonye
Jan 12, 2011 05:50 PM
turbodig
May 9, 2010 12:08 PM
YeeFit
Aug 13, 2008 03:23 PM
