What's under the leather wrap on the steering wheel?
Old Jun 13, 2007 | 11:55 PM
LAFreak's Avatar
I would like to take off the leather wrapping on the steering wheel and was wondering what was underneath. I'd like to replace it with a different steering wrap. I have the Sport and didn't know if there was anything to worry about because of the paddles.
Old Jun 15, 2007 | 12:20 AM
aznguyen316's Avatar
not sure if it would affect the paddles, but maybe look for pics of base steering wheel? Probably would look like that, since base's are leather wrapped.
Old Oct 1, 2007 | 11:55 PM
b-spec's Avatar
hey ill buy you leather wrap if its still useable.
Old Oct 5, 2007 | 06:09 PM
teterman2000's Avatar
I've got a fit base, we should trade steering wheels (except for all those pesky buttons and wiring)
Old Aug 16, 2012 | 01:01 AM
Lance's Avatar
Just got a oem steering wheel wrap. Any advice for installing it? IE sewing it? Please
Old Aug 16, 2012 | 10:10 AM
fujisawa's Avatar
I feel strongly that the sport leather wheel is not a "wrap" over a base wheel per se, but actually a different rim component entirely that is delivered as one "prewrapped" piece. Could even be from a different supplier, although probably not; most steering wheels are metal with a plastic covering and the supplier can just design two versions, one for leather one for not. I have put leather wraps onto wheels before and they always end up coming out a lot thicker-diameter because you add ~1mm in thickness from the leather. Potentially extremely high-quality leather could be very thin, but given the cost I doubt it.
So I expect if you remove the leather you will sort of end up with a wheel that is actually a bit thinner than stock. Rewrapping the unique areas around the thumb grips will be hard but not impossible
But I know someone on this forum re-stiched their wheel with red threads - do a search and see what it comes up with. Should give you more info than I can
Jesse James
Feb 19, 2019 05:50 PM
GotFitB13
Jul 13, 2015 01:47 PM
spryter
18
Aug 8, 2014 05:39 AM
Manga_spawn
Nov 29, 2011 11:39 AM
nsx280ps
Nov 7, 2006 05:18 PM
