96 civic temperature control slider
Old May 4, 2005 | 11:16 AM
schwarzgroup@hotmail.com
Guest
Posts: n/a
I am having a problem with my 1996 civic's temperature control slider.
I don't think it's connected any more to the mechanism. I read here:
http://www.realcaraudio.com/forums/s.../t-226492.html
that on the 94 model you can get to the area by taking out the stereo.
Can you do the same on the 96 model? If so, does anyone have any
instructions I can follow?
Thanks,
Chris
Kevin McMurtrie
Guest
Posts: n/a
Re: 96 civic temperature control slider
In article <1111079858.014196.51150@z14g2000cwz.googlegroups. com>,
> Thanks,
> Chris
In this order: Take out the center armrest, the shift console, the
glovebox, left and right lower dash panels, the lower center console,
two bolts behind radio, the radio, the mystery pocket, and then the lift
out the climate control panel as far as needed.
Yeah, that all sucks. See if you can find the problem with a flashlight
first. There are two heater air valves; one on each side of the heater
core. There's also a hot water valve but I can't remember where it is
at the moment. All three components must move together for the heater
to work.
bourne1
Apr 22, 2017 04:07 AM
buznee
Sep 9, 2013 03:28 PM
adam1979
Aug 23, 2011 07:52 PM
Brandy  Alexandre
Oct 8, 2005 10:31 AM
me
May 4, 2005 11:16 AM
