Temperature control faulty - Blinking red light
Old Aug 21, 2011 | 10:46 PM
adam1979's Avatar
I recently fitted a new double DIN stereo in my 2002 Honda Fit Sport and at about the same time my climate temperature control stopped working.
So everything on the climate control functions fine except for the temperature which seems to be at a constant outside temperature which isn't too pleasant on those winter mornings!
I pulled the central console out (as I did when I fitted the stereo) to see if any of the sockets were loose on the back of the climate control unit but all looked good. One thing I did notice though was a blinking red light in the back of the temperature control. It blinks 7 times. You can view it in a video here.
Does anybody know what this means?
Perhaps I just have a faulty thermostat and it is nothing to do with me fitting a new stereo?
Old Aug 23, 2011 | 02:16 AM
adam1979's Avatar
Dtc 7
Tried once again searching google but this time with some different keywords and believe I may have found a useful site regarding the flashing light -
How to Troubleshoot the Climate Control System
It looks like DTC 7 described here - How to Troubleshoot the Climate Control System
All I have to do now is check for some bad connections on the plugs/sockets at the back of the controls. I guess yanking out the whole console could have pulled on something.
Update to come.................
Old Aug 23, 2011 | 10:57 AM
Krimson_Cardnal's Avatar
You guys get a totally different unit than we do here in the USA. We see a mechanical control unit that opens and closes flaps in a heater box and a switch that engages the AC compressor.
Curious to know if your system controls the dampers off the engine vacuum with the electronics controlling the valves.
Old Aug 23, 2011 | 07:52 PM
adam1979's Avatar
Yes, I noticed when I came across a US reference manual that there were some differences. This car was imported 'used' from Japan to NZ about a year and half ago.
Everything on the control unit seems electronic. I believe that the US model has 2 mechanical cables whereas this one has only 1 that controls the fresh air/recirculation, everything else seems to be electronic.
I have checked my connections visually and everything seems to be okay. Now I need to find out where the Air Mix Control Motor is to check the connections at that end - I have no idea where it's located!
GinoLicious
Jul 26, 2024 10:31 AM
BobinMO
May 20, 2023 08:24 PM
degnaw
Jul 6, 2018 11:58 AM
sdavid12
Dec 4, 2017 08:11 AM
marklj
Oct 7, 2014 02:14 PM
