Where I put my GPS
Old Jun 23, 2007 | 10:38 AM
Anphoe's Avatar
Where I put my GPS
This is where I put my GPS. I attached it on the left front small triangle window. I am right handed, but usually I don't touch it when I am driving, and it won't block my view... just a suggestion.
Old Jun 23, 2007 | 12:48 PM
End-i's Avatar
I never tought to put mine there. Looks great.
Mine is on the usual lower middle windshield.
Old Jun 23, 2007 | 07:40 PM
JDM_DOHC_SiR's Avatar
Looks good there..
Old Jun 24, 2007 | 01:11 AM
Endless's Avatar
That's where I used to keep mine until I got my windows tinted, now I leave it in my center console or in the middles of my windshield.
Old Jun 25, 2007 | 02:27 AM
xdimsumx's Avatar
i wanted to put mine there but i have the garmin c330 and it doesn't adjust sideways that much, only up and down
looks great there
Old Jun 25, 2007 | 11:38 AM
FITrunner's Avatar
Mine sits on top of the dashboard to the middle. I thought about putting it on the triangle window like you did but I am paranoid that it might randomly fly out the window on a turn or something since I usually drive with the window rolled down. Plus when it gets really hot I have already experienced the two sided tape coming off, I dont want it to happen with the unit so close to the window.
Old Jun 25, 2007 | 02:23 PM
smatts's Avatar
Honda Fit Forums Moderator
I have a Nuvi 360, and was planning on installing it in the same location once I got my fit.
Old Jun 25, 2007 | 02:35 PM
macbuddy's Avatar
Never thought of placing the GPS there...that's a great spot, easy to see, and out of the line of sight. Hmm...will this location affect deployment of the air curtain on the Sport models?
Old Jun 25, 2007 | 10:59 PM
radareclipse's Avatar
You might not get great signal strength there. Have you tried it yet?
Pro Fit has a bracket that clips into place in that area and it would put the the GPS out a little more for better signal.
Old Jun 25, 2007 | 11:11 PM
Anphoe's Avatar
My GPS works fine in that position. I don't have any signal problem at all
Old Jun 26, 2007 | 01:35 AM
hotkamote's Avatar
hahaha i did the same thing :P
Old Jun 26, 2007 | 01:38 AM
eNAyeM's Avatar
same place as mine, but run your wires down and under the plastic near the pedals, keeps it clean. i have both the power and a stereo cable running, so i take my calls in surround sound.
Old Jul 21, 2007 | 02:26 PM
jake95825's Avatar
Did the same thing...
Too funny. I just got my nuvi and installed it in the same place. In CA it is illegal to intall anything on the front windshield. My only concern is that if the window attatchment loses its suction and pops off, the gps unit might roll out the window if it is down too far.
As far as the signal, I have had no problems with the garmin nuvi. The new chipsets work really well. If you do have a problem, turn the unit on and leave it on the dash for a minute while it locates the signal. Once it locks in, then move it to the side window.
Old Jul 23, 2007 | 01:24 PM
eNAyeM's Avatar
The suction cup will lose its sucky...ness IF you ever move it. But that is mostly due to it being dirty. I originally had the nuvi on the dash with the sticky plate, but then I moved it to the side and it REFUSED to stay on. I cleaned it with windex and that fixed the problem. It hasn't fallen off again since. And I've never had a problem getting reception at that location either.
Old Jul 23, 2007 | 02:33 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Same place as me also. Mine hasnt looks suction and its been there for a while now.
I ran the power wire down and under the steering wheel. Almost out of site.
Old Jan 31, 2010 | 07:48 AM
crash001's Avatar
I have mine there as well much better than putting it in the center
colnago
Mar 24, 2014 12:12 PM
PocketGoddess
Texas Community
May 6, 2013 03:57 PM
fitandfabulous
Oct 12, 2012 12:17 PM
davejulien
Mar 31, 2009 03:33 AM
garett
Aug 2, 2006 12:35 AM
