17*7 +50 with 205 40 17 and Stech
Old Jul 18, 2007 | 07:04 AM
lilcat's Avatar
got all the stuff now.(17*7 +38 offset wheels with 205 40 17 tires and S tech lower spring)
but got a problem too. the front rubs the fander a lot. total dim is 1 inch bigger than stock wheels and tires.
please help for solutions. should i go to 16" wheels? what biggest size i can do with no rubs? thanks
Old Jul 18, 2007 | 08:02 AM
JDM_DOHC_SiR's Avatar
Originally Posted by lilcat
got all the stuff now.(17*7 +50 offset wheels with 205 40 17 tires and S tech lower spring)
??? Wow ... When I used to run my S-Tech`s on my GD1 .. I barely rubbed... and after I bent the front finder liner plastic tabs I never rubbed again and this was with a 17x7 with a 38mm offset...!?.. ... with 205/40/17 for tires ...
But I would think at with a front wheel with a 50mm offset ( 12mm more clearance that what I had ) you wouldn`t have any issues.??
As of now what is your fender height per side front and rear..?? may be your car might be sitting lower... and if you have pic`s .. post them up .. so I can help you
Old Jul 18, 2007 | 12:37 PM
MarkyMark's Avatar
Are the front spring rates the same? I know on a couple civics I had the higher spring rate had to go on a certain side. Also the overall diameter of a 195/55R15 tire is 23.4 inches and a 205/40R17 is 23.5, according to a plus size guide I have. How is the dia an inch bigger?
Old Jul 18, 2007 | 02:34 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Why on earth would you get new rims because of rubbing? Why?
Fix the problem. Roll the fenders. If you cant do it take it somewhere. Dont get new rims.
Id like to see pics.
Old Jul 18, 2007 | 05:42 PM
lilcat's Avatar
mistake for the offset.. it was +38...so i thank i got the same setup of you. did you have rubs on the rear?
Old Jul 18, 2007 | 06:45 PM
Yes I had small rubbing on the rear bumper mount but I was able to grind off 5mm from it and the rubbing was gone....
Old Jul 18, 2007 | 08:08 PM
BBRFit's Avatar
Just get your fenders rolled
Old Jul 23, 2007 | 05:55 PM
lilcat's Avatar
fander was rolled. normal driving is ok. no rubbing. but when i driving 80 mph it rubs at small bumps. also when i u turn. the front rubs too. do you have the same problem?
Old Jul 23, 2007 | 10:24 PM
redrumm's Avatar
lets see em on the fit
Pmpn8ez05
Oct 7, 2011 01:21 PM
JDM-Taffeta-S
19
Oct 4, 2011 06:15 PM
Java^FiT
Aug 2, 2010 02:01 PM
YeeFit
Oct 10, 2008 07:48 PM
AtticusFit
Jun 21, 2008 12:55 AM
