Independent Foglights Problem Cannot Solve
Old Aug 13, 2007 | 07:34 PM
boyetssilverfit's Avatar
Question Independent Foglights Problem Cannot Solve(BASE MODEL)
I finished installing my foglights last night,now i wanted to use my foglights independently,i was trying to follow Leonines instructions on the independent foglights problem solved thread but i encountered another COLOR TRAGEDY,the instruction says cut the red/yellow wire,so i was looking on both harness and i can' t find it,tell me guys am i COLOR BLIND ?heres the picture so you can judge me if i'm color blind or this is another HONDA's color mistake,first picture is left harness,
second picture is the right harness,
Please help me guys,i dont want to cut the wrong wire,its so strange that i dont have the red/yellow wire that needs to be cut to solve the problem,i got the yellow/brown & red/white but not the red/yellow
Old Aug 13, 2007 | 08:38 PM
Raimondas's Avatar
Do you have a base model?
In order to get my base fogs working with the highbeams, the Red/white wire I had to cut was on the actual fog switch not the relay like that thread shows.
Old Aug 13, 2007 | 09:39 PM
To Raimondas,
yes i do have a base model,which wire did you cut and please tell me what color,and if possible could you please post a picture so i can clearly see which wire or wires that you cut ?
Old Aug 14, 2007 | 01:56 PM
where are you raimondas ?
Old Aug 14, 2007 | 07:55 PM
Raimondas's Avatar
I'm not using the independent control, just fogs on with the high beam. I can post a pic tomorrow if your interested. There's two mods in that long thread, fog+high and independent control. They can be used together or separate.
Old Aug 14, 2007 | 09:56 PM
yes,i'm interested,please do post a picture so i can follow the directions.
Old Aug 15, 2007 | 10:53 PM
Old Aug 16, 2007 | 09:56 AM
Raimondas's Avatar
sheesh, everyones in a rush,
Cut the red/white wire on the back of the fog swtich. The side that goes to the switch now has to be grounded. I used the bolt for the hood release. Tape off the other side. This will allow the fogs and high beam to work together.
Old Aug 16, 2007 | 12:09 PM
Thanks a lot raimondas,sorry,didn't mean to rush you.
Old Aug 19, 2007 | 08:41 PM
Spule 4's Avatar
frazzledglispa
Dec 23, 2015 08:24 PM
xenomorph
Feb 14, 2011 04:10 AM
Klasse Act
Jan 22, 2011 11:22 PM
1990hondahf
Jan 5, 2009 10:43 PM
Jesus
Aug 16, 2006 07:27 PM
