Sponsored by:
Sponsored by: CARiD
Honda Civic remote starter for the Fit?
Old Aug 27, 2007 | 11:32 AM
t-bone's Avatar
Can the 07-08 Honda Civic remote starter be installed for use in the Fit?
I found it from this website:
Shophonda365.com - Canada's online source for all things Honda!
If anyone has any info, I'd greatly appreciate it.
Thanks.
Old Aug 27, 2007 | 11:39 PM
JaySmith's Avatar
I too have been pondering the idea of if this item is possible to install into the Honda Fit as well. It would most definitely make a great addition that's for sure.
Old Aug 28, 2007 | 02:06 AM
jeimusu86's Avatar
this would be a complete waste of money...but id still do it anyways too..hehe...try calling honda's service department if u wanna know if it works
Old Aug 28, 2007 | 02:20 AM
03DSM-RSX's Avatar
Frequent FitFreak Poster
its very possible to do it. u just gota know your way around your wiring.
you can make a remote start system from any generic system. Some, even utilizing your stock remotes. (program auto start by pushing unlock 3x under 5secs.)
also, with the stock system, it may be a bit tricky without the service manual's instructions telling u how to disable the immobilizer during auto startup and a pinout diagram. If u can get ahold of such diagram, it should be easily to convert to Fit's specs.
with a generic system, you would be using DEI's 555H/555U's immobilizer disable module. You can find it cheap on ebay.
Old Nov 11, 2007 | 12:23 PM
Xaositek's Avatar
I am getting ready to put a full Remote Start/ Alarm / Keyless (yes sadly its not just a RS piece) but I know the Fit requires a fairly expensive $70 bypass on the Security system so you don't get into trouble with the Immobilizer.
Keep that in mind and best of luck.
NoVAFit
Apr 2, 2016 02:53 AM
guitrldy
Aug 17, 2011 02:45 PM
flyellow
Nov 24, 2009 05:36 AM
reasonstoprefer
Jan 4, 2009 07:11 PM
geepondy
Oct 24, 2008 11:04 PM
