Trailing Arm Bushings-Where to get them?
Old May 4, 2005 | 04:44 PM
WaterWatcher
Guest
Posts: n/a
Hi. I have a '90 Civic and the trailing arm bushings are toast. Local
dealer wants $60 plus change plus tax each. Anyone know of a less expensive
source for these?
Thanks,
WW
jim beam
Guest
Posts: n/a
Re: Trailing Arm Bushings-Where to get them?
> source for these?
> Thanks,
> WW
google this group for the part numbers, then order from
hondaautomotiveparts.com.
Jafir Elkurd
Guest
Posts: n/a
http://www.cheapesthondaparts.com/
"WaterWatcher" <replytogroup@donotmail.com> wrote in message
news:6LCdnfkS2fFjrsbfRVn-rg@comcast.com...
> expensive source for these?
> Thanks,
> WW
John
Guest
Posts: n/a
I'm curious as well. Also, how do you replace them? What tools would come in
handy?
Thanks!
John
expensive
> source for these?
> Thanks,
> WW
jim beam
Guest
Posts: n/a
> expensive
>>source for these?
>>Thanks,
>>WW
come in
> handy?
> Thanks!
> John
just take them to someone with a bearing press. if they're any good,
it's an easy job. i use a motorcycle machine shop - much more picky &
precision oriented.
John
Guest
Posts: n/a
Can I do it myself without a bearing press? I'm sure I can cut the old ones
out somehow with a knife or partially cut them to make one side weaker so I
can take out the old bushing. Can I put the new one without a bearing
presss? Maybe put some grease on it, and somehow push it in? Would a vise
work and have some kind of rod in there that pushes on the bushing?
Never replaced a bushing in my life and my control arm ones are going out...
will have to get it done soon.
Thanks!
John
"jim beam" <nospam@example.net> wrote in message
news:1113361672.f2ce046083ecde08a4316bb19dedaf90@t eranews...
> > expensive
> >>source for these?
> >>Thanks,
> >>WW
> come in
> > handy?
> > Thanks!
> > John
> precision oriented.
jim beam
Guest
Posts: n/a
>>>expensive
>>>>source for these?
>>>>Thanks,
>>>>WW
>>come in
>> > handy?
>> > Thanks!
>> > John
>>precision oriented.
old ones
weaker so I
out...
> Thanks!
> John
no, you need the tool. and the last thing you want is grease. the
bushings are only held in by friction - if you reduce that, you're in
trouble. similarly, grease rots rubber...
trust me, i'm a big d.i.y. guy. if you could reasonably do this job
without the tools, i'd be there but this is not one of those occasions.
last time i had it done, it cost me $60. quick & cheap. just be
grateful you're not paying to replace the whole arms like it says in the
manual or what the dealer would do for you.
Nightdude
Guest
Posts: n/a
In the Helms book I have says to use sillicone grease on bushings.
news:1113449138.61c1338326c3a26ab025c0d316a47652@t eranews...
>>>>expensive
>>>>>source for these?
>>>>>Thanks,
>>>>>WW
>>>come in
>>> > handy?
>>> > Thanks!
>>> > John
>>>precision oriented.
> old ones
> weaker so I
> > vise
> out...
> > Thanks!
> > John
> last time i had it done, it cost me $60. quick & cheap. just be grateful
> you're not paying to replace the whole arms like it says in the manual or
jim beam
Guest
Posts: n/a
>>>news:1113361672.f2ce046083ecde08a4316bb19dedaf9 0@teranews...
>>>>>expensive
>>>>>>source for these?
>>>>>>Thanks,
>>>>>>WW
>>>>come in
>>>>>handy?
>>>>>Thanks!
>>>>>John
>>>>precision oriented.
>>old ones
>>weaker so I
>>>vise
>>out...
>>>Thanks!
>>>John
only the bushings that have relative sliding motions like on the sway
bars. "fixed" bushings like the trailing arm pivots shouldn't have any,
particularly not on the steel donut outer which is the interference fit.
you are right however that silicone /does/ work with rubber, all
except that silglyde stuff. it /says/ it's silicone, but it gets all
sticky & gummy in no time. utter utter garbage - /never/ use it.
Sparky Spartacus
Sep 28, 2005 07:18 AM
sagar.joshi@gmail.com
Sep 22, 2005 11:30 AM
merlotbrougham@hotmail.com
May 4, 2005 04:44 PM
TeGGer®
May 4, 2005 11:16 AM
TeGGer®
