2004 CR-V replacement tires
Old May 4, 2005 | 04:44 PM
Old_dejanews46
Guest
Posts: n/a
2004 CR-V EX
P205/70R15 95S
When replacing tires, how important, other than replacing all 4 at once
on the CR-V, does the model of a manufacturers tire matter?
For instance, when you go to tire selection for Michelin or BF Goodrich
and select tires by vehicle year, model, the results may show only one
to 3 recommended tire models even though there are many more tires of
the same size in other tire models.
Gary
Guest
Posts: n/a
Re: 2004 CR-V replacement tires
Think with AWD or 4 WD your are suppose to replaced all 4 tires at the same
time.
I have the same car and going to get Michelin Hydroedge.
Gary
"Old_dejanews46" <dejanews46@yahoo.com> wrote in message
news:1113777162.835239.58410@g14g2000cwa.googlegro ups.com...
> 2004 CR-V EX
> P205/70R15 95S
Old_dejanews46
Guest
Posts: n/a
For instance, at www.bfgoodrichtires.com, in the tire selector option,
if you plug in CR-V, 2004, it only returns the "Control Plus" model for
size 205/70R15 95S.
Yet Goodrich makes other tire models with the same specs, but they
don't recommend them, i.e. Traction/TA, etc.
Same for Michelin, it only returns Harmony, Symmetry, and XW4, yet
there are many more models of the same size and specs. Some are under
"SUV" and some under passenger tires...
motsco_ _
Guest
Posts: n/a
> size 205/70R15 95S.
You could hang over at hondasuv.com, and use the SEARCH to see what
everybody else has has success with. Be particularly careful about NOISE
rating. The factory ones are bad for that, so you don't want to repeat
that mistake.
'Curly'
TomP
Guest
Posts: n/a
> 2004 CR-V EX
> P205/70R15 95S
Only as it would relate to the vehicle's use. That is, if you
never drive off/road or on snow or ice. An appropriate size and load rated
"ROAD" tire should be fine and probably will ride smoother and quieter. A
straight road tire might wear better too.
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
Old_dejanews46
Guest
Posts: n/a
I ended up replacing the Duelers with Goodrich Touring T/A Pro series
70,000 mile tires.
Much smoother, quieter.
know-nothin
Nov 15, 2017 04:17 PM
ritholtz
Feb 25, 2017 11:32 AM
spundun
Jun 30, 2011 11:15 PM
jcfit
Mar 26, 2011 03:37 AM
interestingstuff
Sep 12, 2009 02:01 PM
