Underhood Temperature?
Old Sep 29, 2007 | 08:27 AM
Wave's Avatar
Question Underhood Temperature?
Simple question. Or is it?
How hot does it get under the hood of the car? Anyone have any actual Farenheit readings?
Old Sep 29, 2007 | 02:02 PM
ezduzit's Avatar
My SSI intake draws underhood air and my Scangauge reads out intake temps.
The highest temps I've seen are when driving off after being parked for a short period of time on a hot day when the car has been parked after being driven.
Underhood temps in those circumstances are about 130-140F. They drop rapidly once I begin driving and there is some airflow.
ed
Old Sep 30, 2007 | 05:00 AM
claymore's Avatar
Short memory, I had a big write up and here is the results. All measurements made with Fahrenheit scale indoor/outdoor dual reading thermometer. Readings taken in different spots with probe remaining in place for 2 days.
All readings taken after engine reached operating temperatures BUT remember my Jazz has a low temperature fan switch and thermostat and my operating temperature is 180 not the normal 200+ in a normal Fit/Jazz so readings on a standard Fit I would estimate would be about 5-10 degrees higher than my readings.
Right behind the radiator in the center of the engine bay 165-170.
Right on top of the plastic engine cover in the center 155-160.
On the side where the intake comes in from the fender 140-145.
Inside the fender near the intake entrance 115-120 depending on outside temps.
Between the battery and intake 145-150.
Low down between the transmission and radiator where some intakes entrances are. 130-135.
X6Jeopardy6X
Sep 13, 2016 10:11 AM
spoonek4
Dec 10, 2009 12:23 AM
07fitsport
21
Nov 7, 2009 06:58 AM
FitCanada_Girl
Nov 8, 2008 10:09 AM
