16x7 wheel with 3" lip *WOW*
Old Oct 1, 2007 | 09:33 PM
danger69's Avatar
I was browsing through eBay and found this. Even though the offset is +38 it should be no problem. With these wheels it will make the fit look VIP style or EURO.
eBay Motors: 16 Wheels 3" Lip Honda Fit Civic Miata Mini Cooper Rims (item 230176247941 end time Oct-03-07 13:45:00 PDT)
Old Oct 1, 2007 | 11:45 PM
mimpi's Avatar
its called a fake dish. where the spoke concave to create that dish lip looks even deeper.
Old Oct 2, 2007 | 12:02 AM
Sugarphreak's Avatar
Push My Button
A +38 on a 16" wheel?
Hmmmmmm, even with a 195/40 I think you would run into rubbing trouble.
Old Oct 2, 2007 | 02:09 PM
TOOL's Avatar
I dont think those kind of wheels look to ggod on the Fit, IMO..
Old Oct 2, 2007 | 02:12 PM
JDMchris.com's Avatar
I run THIS
im running 16" +38 on 205/45 no rubbing
Old Oct 2, 2007 | 04:11 PM
Push My Button
Man!!! How are you guys getting away with this stuff??? A +38 offset with a 205 would have me dragging my fender into the wheel! Your dropped too arn't you? What brand of wheel are you running?
Old Oct 4, 2007 | 04:01 AM
jtanoyo1's Avatar
It's called camber. If you go a lot negative camber, it's not impossible to put on 16x8 +20 wheels and stretched tires and not do much to your fender but rolling them only...and you won't rub even though you are dropped....
...can't say much about the tire wear though.
Old Oct 4, 2007 | 07:11 AM
I run THIS
Yes im dropped, on Rays 57optimise. previously I was on Enkei Racing S 205/50/15 +32 offset with minimal rubbing.
Old Oct 4, 2007 | 07:22 AM
JamesBizzle's Avatar
damn, you're still up chris.... shiet.... crazy... anywho
+35 on 205/50/15 azenis rub.
I think 205/40 would be straight though.
Old Oct 5, 2007 | 04:04 PM
Push My Button
Yeah I am starting to think my car is weird or something, today on my way home I passed through an interesting construction area in a 100km zone where they have engineering a huge long dip that leads into a large bump. I kind of feels like you are becoming airborn, then the bump comes and the whole car compresses into the ground.
Anyway, my point is I rubbed on the rear when I through it Granted my GF210's don't give me much camber change, but I am running +45 offset with 195/40R17 tires.... so... WFT!! Luckily I havn't had any rubbing anywhere else for months, but stilll... I totally don't know how you guys are doing it, my car is a picky bastard when it comes to tires.
Old Oct 5, 2007 | 04:16 PM
I run THIS
im on coilovers, stiffer spring rate, and dampened rate.
Old Oct 5, 2007 | 04:33 PM
redrumm's Avatar
i bet those rims are heavy as hell
Old Oct 5, 2007 | 04:55 PM
Push My Button
I guess the higher dampener rate would help for sure, my current spring rates are already pretty high with the Tanabes.
I didn't really consider the weight of the wheel, do you think that would have a huge affect on how the suspension behaves over bumps? RTX isn't exactly known for making lightweight wheels, I think they are around 18lbs each for the rim... no idea regarding the tire.
Old Oct 5, 2007 | 05:31 PM
redrumm's Avatar
those sportmax vip wheels are like 20 something. i dont even think they are worth buying IMO
Old Oct 5, 2007 | 07:19 PM
Push My Button
Oh yeah... forgot this was a thread for the rims Talk about getting off-topic! Sorry redrum I though you were adding to Chris's comments.
Agreed, those rims at the top look ultra heavy!! If I had to guess it would be way more than 20lbs each.
Old Oct 5, 2007 | 08:54 PM
Jazz GD3's Avatar
now i look at it, i think these are almost the exact rims that the JDM Kenstyle Fit uses isnt it? maybe a replica or some sort, but it looks almost identical
Old Oct 5, 2007 | 10:10 PM
redrumm's Avatar
similar but not the same.
Old Oct 8, 2007 | 10:23 AM
t3chn0rav3rb0y's Avatar
i think you rubbed because you have a 17" on the fit..by having 17's with a 205 that would cause rub atleast i think so
Old Nov 9, 2007 | 06:55 PM
aspecproducts.com's Avatar
the term is not CONCAVE, its CONVEXED.
Old Nov 9, 2007 | 07:11 PM
mimpi's Avatar
o yeah? i see..
CelestialBlue
Jul 6, 2013 08:01 PM
danger69
Oct 25, 2009 10:46 PM
Mayo
Jul 28, 2009 05:03 PM
sLiVeRwOrM
Nov 2, 2008 02:48 PM
drock305
Oct 1, 2008 12:11 AM
