Zeta parts problem? Anyone else?
Old Nov 4, 2007 | 12:09 PM
noyzz's Avatar
So I got my new goodies from Zeta yesterday. I purchased the dead pedal and the billet fit oil cap. I installed them today but I noticed that the dead pedal once installed the kick panel cover doesn't fit like it did before. The top clip won't clip back in. Any info on anyone that has had the same problem? Now on the oil cap I noticed that the fit logo won't line up horizontal so when you open the hood it won't be facing you. I can only get it to line up vertical. Any one else have this problem?
I've e-mailed Zeta so I'll wait and see what they say, but any info would be great as well.....
Thank you....V
Old Nov 4, 2007 | 01:16 PM
Cat's Avatar
Cat
I think I've seen post on the oil cap with same comment that it does not line up so you can see it - let us know what Zeta tells you - I just ordered some parts last night but only cosmetic items that should work fine on the car.
Cat :x
Old Nov 4, 2007 | 01:26 PM
koolkevin1107's Avatar
are you sure that u installed it correctly? mine fits in perfectly and went in no problems. Double check your install. Also, the kick panel goes in a certain way. I think you have to slide it (cuz there is a hook) then the clips fall into place.
Old Nov 4, 2007 | 10:05 PM
noyzz's Avatar
Yeah for the dead pedal it's installed right. I followed the instructions that came with the pedal. But if you look at the fine print in the instructions it says the top clip as in the middle clip won't clip back in. Only the bottom and the rubber gromet at the top.
Haven't heard from Zeta yet but will keep you posted....
Old Feb 22, 2011 | 04:58 AM
Chieftain's Avatar
My car has been making a squeaking noise for over a month period. I have done a diagnostic test and everything was fine. I also change one of the belt but it is still making noise. One mechanic guy told me that sands have entered in the belt and cause the noise. Can this cause a serious problem if I don't change it soon.
THANKS...central air conditioners
Fit4Pits
Mar 15, 2015 07:56 PM
los_creeper
Jul 14, 2008 11:26 PM
fork_nSpoon
Jul 5, 2008 05:48 PM
harajuka
Dec 12, 2007 02:54 PM
LiL Wee FIT
Toronto Community
Oct 15, 2006 01:09 PM
