Progress Sway Bar Issues
Old Nov 15, 2007 | 10:54 AM
Hocker's Avatar
Senior Member
I'm not sure if a lot of you have had this issue but we did on both our Fits. We installed the Progress rear sway bar. Everything was great until we noticed the hardware actually pushes into the spring. Not really a huge issue with OEM springs but it is pushing and putting stress on the spring. I have my Fit lowered and it was causing issues making the spring rub into the sides and making noises. We designed a Kit that fixes that issue if anyone has had the same issue.
Old Nov 15, 2007 | 12:53 PM
carlosalicea's Avatar
i have the bar and progress springs......... no isue in the back.
In the front, the left side sounds very anoying, but I did not cut the piece it says inthe instructions nor put any rubber in the lower part to avoid noises.
Old Nov 15, 2007 | 01:23 PM
Hocker's Avatar
Senior Member
Hmm well the progress rear sway bar had issues with my Mugen Springs due to the sway bar hardware. I noticed in your signature you don't list the rear sway bar, I wondered if you mistaked sway bar for strut bar. Either way I had an issue with my springs and the progress rear sway bar so we designed hardware to fix that. I also heard others say they had issues with other aftermarket springs with the progress rear sway bar.
Old Nov 15, 2007 | 01:33 PM
Wink
Updated signature.
I do have the Sway bar, and the only thing that worries me is that the rubber in the bottom of the rear springs may broke due to the bar bolts.
but waw the bar was the best mod for the money, I mean you can feel the difference just taking the car out of the driveway. And i auto-x the Fit and after the sway bar, the car rotates as it showld from the begining...I mean is awesome.
P\D: The track lap in the link was the warming lap with the stock Fit.... no nothing.
Old Nov 15, 2007 | 02:30 PM
Hocker's Avatar
Senior Member
Hmm maybe its the design on the Mugen Spring, but either way I found an issue and a solution to that. I also didn't like how the hardware pushes into the rubber. The hardware we sell now fixes that issue as well.
Old Nov 15, 2007 | 05:23 PM
koolkevin1107's Avatar
do uhave pix of ur updated hardware? doesn't it say u have to twist the spring until it doesn't catch the hardware?
Old Nov 15, 2007 | 05:32 PM
Hocker's Avatar
Senior Member
We did the twist thing but it still had issues, like going over speed bumps or other things. Still it should do it at all.
Upgraded Hardware Kit for Progress Rear Sway Bar
Old Nov 15, 2007 | 06:17 PM
gloryhound's Avatar
nice solution... will the bolts be ok with the amount of pressure exerted on them from holding the sway bar in place?
btw how much would it be for the sway bar and the new bolts shipped to LA?
Old Nov 15, 2007 | 08:00 PM
Hocker's Avatar
Senior Member
The quality of the bolt will hold up. We didn't just get a low grade bolt to solve the issue.
Old Sep 7, 2010 | 09:40 PM
Jodele's Avatar
I think I have the same noise problem...
The link no longer works...can you post again?
Old Sep 7, 2010 | 09:56 PM
solbrothers's Avatar
its just that the progress bar isnt made for aftermarket springs (other than the progress springs)
Old Sep 7, 2010 | 10:00 PM
danger69's Avatar
do a search online to find the hardware needed at your local hardware store.
Old Sep 7, 2010 | 10:42 PM
Jodele's Avatar
I just ordered a buch of hardware from McMaster Carr to try and solve this issue.
Old Sep 7, 2010 | 11:25 PM
you might have to grind the bolts, it worked for me when i had skunk2 springs. now im on coilovers, so it isnt an issue
FrumiousBandersnatch
13
Feb 17, 2010 06:34 PM
harispirzada
Apr 28, 2009 09:53 AM
Darkstars
Mar 22, 2008 08:40 AM
lilcat
California - Bay Area Community
Mar 11, 2008 09:36 PM
kennef
21
Jan 26, 2008 09:37 AM
