HELP!! Short Shifter Problems
Old Nov 30, 2007 | 11:00 PM
t3chn0rav3rb0y's Avatar
So i just bought the Skunk2 short shifter adapter and im stuck...can someone help with a detailed version of the install???
Old Nov 30, 2007 | 11:14 PM
Arisenfury's Avatar
Where are you stuck at?
Old Dec 1, 2007 | 12:04 AM
im stuck on the part where i have to lossen the shifter cables by turn the locking ring counter-clockwise. HOW DO I TURN IT!! IT WONT TURN
Old Dec 1, 2007 | 12:29 AM
Illusive's Avatar
Check out this DIY for the Mugen one. It has a pic of your problem with an explanation. Hope this helps...
https://www.fitfreak.net/forums/fit-...t-install.html
Old Dec 1, 2007 | 01:02 AM
okay thanks, but now im stuck again on having to remove the bushing from the pivot ball... i dont want to break the bushing so what should i do
Old Dec 1, 2007 | 01:39 AM
alright...past the pivot ball and bushing thing... now im stuck on the shifter extension... how do i position it correctly over the pivot ball?? I know it says to use locktite, but what is that for?
Old Dec 1, 2007 | 10:37 AM
George02's Avatar
push it all the way up and screw it in
Old Dec 1, 2007 | 12:11 PM
i did that, but the screws aren't holding it in place...and what is the loctite for?
Old Dec 1, 2007 | 12:31 PM
koolkevin1107's Avatar
loctite is basically like a glue for the screws, it prevents them from coming loose. I would HIGHLY RECOMMEND IT because ur always moving the shifter and u don't want it coming loose while ur driving so go get some blue loctite, not the red one but blue is perfect.
Old Dec 1, 2007 | 05:13 PM
the set screws are not holding the pivot ball in place... how do i make it hold it in place.
Old Dec 1, 2007 | 10:06 PM
Tork's Avatar
The allen wrench required is not metric surprised to find out.
And you need your allen to be not rounded off or stripped, you can grind some off on a grinder if needed.
You can only start with the setscrews in a couple of turns, too far in and the extension wont go on all the way. Red loctite is ok too just that you will have to apply heat if you ever want to loosten the set screws.
Old Dec 3, 2007 | 01:15 AM
thanks for all the feed back!! Got i done, but need to get some loctite hah. It feels great! thanks all
pearl
May 24, 2014 07:31 PM
rossmeister
Feb 7, 2012 02:13 AM
andyd
Dec 26, 2009 04:59 PM
No_Skillz
Feb 17, 2009 01:09 PM
xanatos
Aug 26, 2008 11:06 AM
