HID problem?
Old Dec 6, 2007 | 01:50 PM
GeorgeC's Avatar
HID problem?
just installed hids last night but now i'm stuck driving with DRLs, gotta re-aim...
back to the issue, i installed H4 high/lows, with the high being a separate halogen bulb, now whenever i turn my low beams on the high beams light on the dash turns on, and whenever i go to my high beams, my halogen lights up while my hids flash and die off, then i gotta turn all my lights off and go back to low beams for the hids to come back on
i had to rearrange the contacts on the on the hid kit but i'm pretty sure theres two black wires one from each bulb going into one contact on the top of the plug and a red wire from each bulb going into their separate contacts on the sides of the plugs
anyone know what i'm talking about?
i'll try to get some pictures when i have time to take off my bumper and look at everything again
Old Dec 6, 2007 | 09:15 PM
WhEreZmYFiT's Avatar
Miight have to re arrange the wiring from your high beams. If it is a plug and play kit. You have to have the high beams (the two black ground wires and the red wire connect to the stock headlight unit). I had a simlar problem where my HID lights wouldn't work but my Hi- beams would. It all depends on how you ground your wires. I had help from AznCarbos. He help me and now my HID lights are working fine. So just try to re- arrange the wires to get them to work. Good luck
Old Dec 7, 2007 | 02:46 AM
GeorgeC's Avatar
just to clarify
my hid's work as low beams fine right now, but in the dash the high beam lights come on, when i go high beams, the halogens turn on, the hids flash for a sec or two then all the lights die out, and then i gotta turn all the lights off and on to get the hids back
the lows work fine, just that if i hit the high beams i lose my lights
i gotta take a look at the way i moved the contacts around when i get some spare time
anyone else have the same problem with their halogen/hid high/lows?
Old Dec 7, 2007 | 04:05 PM
theljnet's Avatar
Former Vendor
just want to make sure, do you have a Day time running light?
Old Dec 7, 2007 | 10:31 PM
azncarbos's Avatar
dude you need to disable the Day running lights DRL, Canadina Fit are reqiure to have DRL, but w/ HID you are require to disable the DRL
http://havingafit.blogspot.com/2006/...ights-drl.html
Old Dec 8, 2007 | 06:06 AM
GeorgeC's Avatar
DRLs are working fine through the halogen bulb...
should i disable? is that whats causing the high beams problem?
its not really a big issue, i just like to have everything in working order
Old Dec 8, 2007 | 11:11 AM
azncarbos's Avatar
Yea you have to disable the the DRL. to have everything working in order.
airwicc
Oct 30, 2010 11:09 PM
stnl619
Dec 24, 2009 12:40 PM
stockfitgd3
Dec 8, 2008 01:12 PM
enjoito
Nov 12, 2008 02:22 AM
matt7277
Mar 4, 2008 03:13 PM
