AC dims headlights?
Old Dec 6, 2007 | 10:39 PM
J_L's Avatar
J_L
AC dims headlights?
I've noticed that when the AC compressor kicks on the headlights dim slightly. Is this normal? Usually you can feel the drag on the engine but have never seen the lights dim on any other car.
Old Dec 6, 2007 | 10:41 PM
TOOL's Avatar
Ive never noticed? Is it only right when it turns on or is it the whole time the AC is on? May i ask why your running AC this time of year lol?
Tyler
Old Dec 6, 2007 | 11:02 PM
Fit of RAGE's Avatar
normal. Using AC puts a huge load on your engine.
Old Dec 6, 2007 | 11:35 PM
J_L's Avatar
J_L
I'm running the AC because I haven't done the mod that disables the auto on AC with the defrosters. (I hate that "feature") Today in the Willamette valley it's 41 degrees with 98% humidity, defoggers are a must. I can see the lights dim when the compressor engages, when it's not engaged they are quite a bit brighter. I installed ultra stars right after I got it so I wonder if the stock bulbs exhibit the same behavior...
Mr Yoda, I know it's a lot of drag on the engine but I've never seen a car that the lights dimmed, the power lugs down but not the voltage on the electrical system.
Old Dec 6, 2007 | 11:41 PM
TOOL's Avatar
It may be the bulbs you have..I have not expirienced the problem at all.
Tyler
Old Dec 7, 2007 | 12:51 AM
jlmspeedjordan's Avatar
I have noticed what your talking about not only in my fit with stock bulbs but every car ive ever owned. I thought it was a normal thing since the ac creates resistance for the pully on the alternator whenever it kicks on. But maybe ive just owned a bunch of crappy cars.
Old Dec 7, 2007 | 10:07 AM
kndlewis's Avatar
I've seen this at idle but not while actually driving down the road.
Of course, at idle, the engine is not delivering enough voltage to recharge. Only enough to keep the engine running.
Old Dec 7, 2007 | 11:26 AM
F0NIX's Avatar
On my car the front lights just flicker once every time when the AC pump starts. It does not dim the lights when the pump is going.
I think this is normal, and have seen it on many other cars to. On some car you could even feel the power from the motor is slowing down a bit when the AC is on.
Does anybody know if the AC pump is connected direct to the motor or is it only a electric pump on our Fit/Jazz? By my flickering it seems that it is just a electric pump?
Then again, it may be some differences from the EU Jazz and the US Fit since I have an electric controlled AC on my EU Jazz?
Old Dec 7, 2007 | 12:39 PM
Bahumut's Avatar
In my golf, if I hit the power window switches, the headlights would dim. That annoyed me a bit
Old Dec 7, 2007 | 02:49 PM
J_L's Avatar
J_L
I have to say that is is noticeable at low rpms. If it is an electric pump that would sure explain the voltage drop.
Sono
Jul 16, 2017 04:21 AM
sschoe2@gmail.com
Jul 27, 2016 08:40 AM
newhere
Apr 24, 2015 01:44 PM
mhx
Aug 8, 2013 05:48 PM
docjim2
Sep 25, 2006 10:35 AM
