Rear light stuck on 92 Accord
Old May 28, 2005 | 04:41 PM
Jason
Guest
Posts: n/a
I had a dead battery this morning and realized it was due to my rear
brake lights being on all night. I made sure the actual brake was not
stuck and it was not. I found a post similiar to this where the problem
was caused by a "button" under the dash, but I could not find any more
specific information. Anyone?
Thanks
Jason
TeGGeR®
Guest
Posts: n/a
Re: Rear light stuck on 92 Accord
"Jason" <jasong@satx.rr.com> wrote in
news:1116893429.384552.10900@g44g2000cwa.googlegro ups.com:
Brake light switch. At the brake pedal. Probably dislodged.
TeGGeR®
www.tegger.com/hondafaq/
Jason
Guest
Posts: n/a
Thanks for the reply. When I went outside to check I noticed a few more
things. Now the Left brake light does not turn on or off while the
right remains "stuck". In addition, none of the rear driving lights
that come on with the headlights, are getting power
Jason
TeGGeR®
Guest
Posts: n/a
news:1116895743.029117.299860@o13g2000cwo.googlegr oups.com:
Oh boy. You have other problems then, not just the switch.
Check all bulbs for corrosion in all the sockets. Check all grounds. Check
bulbs for burned-out filaments.
Check the backup light swtich at the parking brake lever.
Any rust where you live (or where the car lived before you had it)?
TeGGeR®
Zebra
Guest
Posts: n/a
Had you changed the rear light bulbs recently. Check that they are the
correct ones? One kind of light bulbs got one one contact point at the base
and a pair of parallel locking pins at the sides. The other kind of light
bulbs got two contact points at the base and the locking pins are not
parallel at the sides. Strange enough sometimes one can still screw them
into the wrong sockets by accident.
<TeGGeR? <tegger@tegger.c0m>> ¦b¶lĄó
news:Xns965FD4E98C662tegger@207.14.113.17 ¤¤Ľ¶Ľg...
> TeGGeR?
Steve Bigelow
Guest
Posts: n/a
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns965FD4E98C662tegger@207.14.113.17...
Check the grey connectors by the tail lights. They get corroded by the
leaking tail light gaskets and housings.
BTDT.
Old Jun 3, 2005 | 01:06 AM
Jason
Guest
Posts: n/a
Does anybody happen to know that actual names of the Brake light switch
under the dash and the grey connectors by the tail lights?
Jason
Guest
Posts: n/a
a picture of the switch would be great as well
thanks
TeGGeR®
Guest
Posts: n/a
news:1117657727.289793.294780@o13g2000cwo.googlegr oups.com:
The one under the dash is called a "brake light switch".
TeGGeR®
TeGGeR®
Guest
Posts: n/a
news:1117658237.427391.302350@f14g2000cwb.googlegr oups.com:
> thanks
Why? Can't you see the one on your car? It's a simple plunger switch,
grounded when pressure is removed.
TeGGeR®
daves007
Apr 26, 2015 07:11 AM
chinkyy
Mar 4, 2013 10:37 AM
thomas.jacobs@dva.state.wi.us
Oct 6, 2005 09:30 AM
John Edwards
Aug 21, 2005 03:00 AM
Doug McCrary
Jul 31, 2005 06:45 PM
