Need Feed Back!
Old Dec 12, 2007 | 10:09 AM
t3chn0rav3rb0y's Avatar
Need Feed Back!
I really need help deciding on either the Eibach Pro lowering kit or the Eibach Sportline kit. Who has them and how are they?? Need feed back please!
Old Dec 12, 2007 | 11:21 AM
i dont have them on the car, but the prokits are better matched to your
factory shocks.
Old Dec 12, 2007 | 11:30 AM
Mr_ET's Avatar
Ask JDMish how he likes his pro kit, I believe that is what he has on his car.
Illusive's Avatar
Pro Kit is excellent!
Old Dec 13, 2007 | 02:38 PM
thanks for all the feed back! Does anyone have the sportline kit? I am just interested because it give a huge drop and i am hoping they give a more progressive stance. I just would also like to know if the sport line kit gives better performance than the pro kit.
Old Dec 13, 2007 | 02:44 PM
jeffquach's Avatar
they're both progressive, if you want the lower drop go for the sportlines. i have the pro kit and its great.
Old Dec 13, 2007 | 02:53 PM
there's no such thing as 'better performance' from lowering springs
unless you change out the dampers.
best you can do is try to get the closest spring rates to stock.
problem with eibach is that they don't advertise their spring
rates... do they?
i was able to find most of them except for Eibach and some other
smaller name JDM springs. i ended up going with DF210s cause they
are pretty close to stock.
ciburri's Avatar
I am on Eibach Pro.
It is low enough! I can't even imagine going with Sportline's! Suspension needs travel to work properly.
I am borderline on being satisfied. I am big time into handling, but I got spoiled with Kg/mm Dual Progressive Rate springs with comfort, too. I had them on my GSR and now with minor mod on my CRX. I can't get a hold of them!!@#$%^&*!!!!
Anyway, below is the link to my Picasa album with my Fit before and after pics with Eibach Pro's:
Picasa Web Albums - Ivan - FIT stock vs....
Ivan
Old Dec 13, 2007 | 02:59 PM
TOOL's Avatar
^that looks about 100x better then the stock height, if only they were dual rate.
Old Dec 13, 2007 | 03:26 PM
^^^ +1 that height looks good.
wat do you mean by dual rate? you mean linear rate?
Old Dec 14, 2007 | 10:17 AM
that looks freaking great! I'm Definatly going with the prokit ! THANKS FOR ALL THE FEED BACK!!!
rates... do they?
The DF210s are the tanabe springs right?? how much did they lower u?
Old Dec 14, 2007 | 10:51 AM
will let you know next week... should be coming in this morning.
hopefully i can get it installed tonight, given that i have time to do it.
Old Dec 14, 2007 | 11:32 AM
TOOL's Avatar
Ok well im not an expert on this but i know some by listening to Manxman and Ciburri at meets. Dual rate means when your driving regualar the srings feel like stock, and they are not stiff and harsh, but right when you turn the get really stiff and give you ultra handling!
Tyler
Old Dec 14, 2007 | 01:23 PM
TMATHEWSON1008's Avatar
Talking Awsome !
Pro Kit Has Been Great On My Car. I Love It.
Old Dec 15, 2007 | 12:22 PM
Once again Thanks for all the feed back! But does anyone have the Sportline?
Old Dec 17, 2007 | 01:09 PM
Tyler
that's called progressive rate.
linear rate is just one rate.
Old Dec 17, 2007 | 03:13 PM
ciburri's Avatar
Actually Kg/mm were built with two progressive rates in one spring. As if you have Porsche Cup car suspension with primary and tender spring on each corner.
I am not 100% sure, but I think they got that done by changing the thickness of the coil wire on portion of the spring. I never bothered to measure.
I would not believe it, but I have a set that was for my GSR that I made some top perch modifications to fit on my CRX on Koni's.
Eibach, H&R and likes are very good progressive springs, but these Kg/mm are so different on a car it is hard to believe it is not an active suspension.
Problem is looks like this very small, but highly specialized company in Japan is unreachable. Few members and myself are trying everything to get to the bottom of the situation. If nothing else we will try to find somebody who has some sets left over.
I think I am going to change my signature to give the issue more exposure on the forum. Maybe somebody overseas can help. I started a tread in suspension section a while back and we thought we got close:
https://www.fitfreak.net/forums/fit-...tml#post155103
Ivan
Old Dec 17, 2007 | 04:37 PM
^^ yah, well your link title even states dual rate "progressive" rate springs.
but i see what you're saying. 2 linear rate springs on top of each
other. the soft one collapses all the way and then the rate goes to
the firmer spring which is also linear to provide like a dual "stage"
rate. makes sense.
some people mis-interpret helper springs as tender springs and think
helper springs actually does something to soften the ride. well, it
sorta does, but it's there more to prevent spring rattle at full extension.
interesting.
Old Dec 18, 2007 | 10:50 AM
wow, good info THANKS!
