AVIC-D3 GPS Antenna
Old Dec 14, 2007 | 12:01 PM
joshua27's Avatar
AVIC-D3 GPS Antenna
Where did you guys mount your GPS antenna, that's the only thing I'm unsure with installing the avic-d3.
Old Dec 14, 2007 | 04:39 PM
F0NIX's Avatar
I have just installed the Pioneer AVIC-HD3BT (AVIC-Z2 in the US) and I think the GPS antenna installation is the same for the D3 unit.
From the Honda manual that came with the Honda face plate for dual din installation there was a few steps where they mentioned where the orginal GPS antenna for the OEM NAV-kit should be installed. That one come on a bracket that was mounted with one bolt to a small edge inside the dashboard.
So I just put the GPS antenna in the close proximity of that spot.
It is just in front of the gauges and to the right. There was a ventilation tube going there and I put it on top of that. With that position it is placed almost in the middle of the dashboard and pretty far forward and just beneath the dashboard top. I have excellent reception there.
Had to take out the gauges to get to that spot. But that was necessary anyway because I needed to get the Bluetooth wires/module and speed wire (VSS) over in that directions too...
Old Dec 14, 2007 | 08:19 PM
ToyotaLover's Avatar
do you have pictures of your stereo? I'd like to know if there is a oem panel that us in the US can use...thanks
Old Dec 14, 2007 | 09:15 PM
joshua27's Avatar
Alright, finished install up today. It was surprisingly easy, just time consuming. I highly recommend Avic411.com for anyone with questions regarding install. They have a nice photo spread of how to wire up the D3 to bypass the no video while in motion and no entering of GPS coords.
I ended up mounting my antenna at the small window on the passenger side and routing the cable under the dash over to it. I do think I am going to move it to a position underneath the dash like the above poster said to.
If anyone has any questions, feel free to PM me. By the way, I was told by a professional installer here that the reverse wire was not needed for the GPS to function so I didn't hook that one up. I did hook up the VSS wrie and the bypass still works on a unit manufactured Oct. 2007.
Old Jan 7, 2008 | 10:38 AM
ImPuLsIvE.ca's Avatar
I just installed a D3 in my FIT a few days ago. It was relatively easy, but having to dick around with the HVAC was brutal. I also managed to lose all the mounting clips except for 3-4 of 'em. Damn bastids!
I ended up mounting the GPS antenna just above the driver's side vent near the window. Looks nice and clean there and has plenty of view to the sky (counted over 7 satellites connected).
I have a D3 in the Prelude aswell. I just love these units!
Old Jan 7, 2008 | 03:56 PM
F0NIX's Avatar
Pictures of my installation can be found here:
Navi unit (sorry for the missing thumbnails, will be corrected soon)
Same pictures (with thumbnails) could be found here until the first site is fixed: Flickr: Photos from F0NIX
I don't think you have that automatic A/C system (with digital display) that I have on my car, so the same panel could not be used. But I know that the 2005 (and older) Jazz have that manual A/C system with the three knobs that you have in US and there is a facepanel avaiable for those cars too.
And on this page you'll see where the OEM GSM antenna is mounted.
Last edited by F0NIX; Jan 7, 2008 at 05:18 PM. Reason: added link to GPS antenna installation/removing
Old Jan 7, 2008 | 09:45 PM
abcsr2ez4me's Avatar
Nice Setup Fonix!
LLLC1393
Jun 8, 2011 10:00 PM
Chazzlee
Jan 16, 2010 05:48 PM
hdr242
Aug 2, 2008 03:08 PM
NjBlazin07
Sep 9, 2007 10:41 AM
joe Winston
Jul 25, 2006 11:17 PM
