Stock Wheel Weight
Old Dec 15, 2007 | 10:47 PM
Tel1sps's Avatar
Stock Wheel Weight
Does anyone know how much the stock 15" sport wheels weigh? I'm looking for a new set of wheels for street/track that weigh less... and want to know stock weight for planning.
Old Dec 15, 2007 | 11:13 PM
claymore's Avatar
Try searching or looking in the shoes section the answer you are looking for has been covered in SEVERAL POSTS.
Old Dec 15, 2007 | 11:33 PM
TOOL's Avatar
https://www.fitfreak.net/forums/fit-...k+wheel+weight
As Claymore said, search is your friend!
Tyler
Old Dec 16, 2007 | 02:36 AM
MINI-Fit's Avatar
Calculated estimate 16.4 lbs each stock 15" rim.
Old Dec 16, 2007 | 12:52 PM
Tel1sps's Avatar
Thanks for the info
Old Dec 20, 2007 | 12:55 PM
Tel1sps's Avatar
Too bad the Mugen NR wheel weighs so much at 16.5lbs. It is the same as stock so you don't gain any performance, but you don't lose any at least. (cost $295ish)
The Enkei RPF1 in 15x7 is only 9.5lbs which would make a big difference being 7lbs lighter. (cost $200ish).
My other choice would be a Volk CE28 which I hear is approx 7lbs but cost alot more.... approx double the Enkei ($400+)
If anyone knows of other light wheels that I should consider please post up
Old Dec 20, 2007 | 01:36 PM
kennef's Avatar
RPF1 for the win. the only time i have seen any problems with the RPF1 was under some extremely heavy track work with brake calipers that barely cleared the wheels. i honestly can't believe that there are wheels that combine the level of weight, strentgh, and low price that these do.
Old Dec 20, 2007 | 01:50 PM
Tel1sps's Avatar
Nice, Do you have pics of them on your car that you can post?
Old Dec 20, 2007 | 03:52 PM
kennef's Avatar
check this thread: https://www.fitfreak.net/forums/fit-...periences.html
Old Dec 21, 2007 | 08:39 PM
Tel1sps's Avatar
The RPF looks real nice in 17"... I'd personally go with 15" to get the reduction in rotational weight. But on the other hand I may go up to 16" in a forged wheel for track duty.
Old Feb 20, 2008 | 08:22 AM
john trials's Avatar
A friend of mine just measured a 2008 Fit Sport rim (with the TPMS valve stem attached) on a VERY accurate scale at his work.
17.45 pounds.
Old Feb 20, 2008 | 12:48 PM
MarkyMark's Avatar
XXR (formerly Sport Max) 003! 15x7 10.8 lbs
Old Feb 20, 2008 | 01:27 PM
Tel1sps's Avatar
17.45 pounds.
Thanks for the help! Good info for everyone to have. Good point also that depending on the year that the wheels may have different weights. Especially since the 08's have the TPMS.
I'd see a good performance gain going with an Enkie 15x7 that would weigh approx 7lbs less.
Dougr320
Oct 26, 2012 08:44 AM
unclezeno
Apr 4, 2012 11:55 PM
wpgfit
May 16, 2008 12:50 PM
xorbe
May 14, 2008 10:37 AM
GreekFit
Jul 19, 2006 07:06 AM
