15x6.5 offset + 36 no rub?195/50/15 fit perfectly?
Old Jan 6, 2008 | 10:43 AM
FITGD3's Avatar
hey guys
Will 15x6.5 offset +36 fit HONDA FIT perfectly without rub or rolling the guard?
also 195/50/15 tyres ok for it?
any one running 15inch +36 rims on FIT?could you post a pic pls.
cheers
Old Jan 6, 2008 | 11:37 AM
c_mack9's Avatar
those tires are gonna have some small sidewalls. it will run your speedo off a few mph and run the miles on the odometer up a little bit faster. 205/50/15 is closer to stock tire size. it shouldnt rub if you have stock suspension but if you ever lower it, it could be a possibility.
Old Jan 6, 2008 | 02:46 PM
ANT's Avatar
ANT
195/ tire width
50/ sidewall
15 rim size
Old Jan 6, 2008 | 06:42 PM
Originally Posted by FITGD3
hey guys
cheers
considering my 15x7 +40 running 195/50/15 falken 912's dont rub,
im pretty sure your app would work...but use all season tires (tires
with small shoulders).
high perf tires have bulky shoulders and will probably rub. don't
to any wider than 195.
im going to push out my rear wheels out 5mm (will be +35mm)
when it gets warmer.
Old Jan 7, 2008 | 11:47 AM
FITGD3's Avatar
cheers man.
Old Jan 7, 2008 | 11:49 AM
Illusive's Avatar
ehhhh +36 is cutting it close. For example, if you go up to 17's I had +42's and rubbed while another member had +45's and didn't rub...that extra +4 can make or break the setup...it'll all come down to your tire tolerances...
Old Jan 7, 2008 | 11:51 AM
FITGD3's Avatar
+36 will be fine mate.. Check out 15inch for most of wheels for sale.
they come with 15x6.5 +36 mainly.
Old Jan 15, 2008 | 10:57 AM
tattoopunk031's Avatar
Im lookin at getting konig rims that are 15x6.5 with a 40mm offset. Will that work with 195/55/15? Thats the recomended tire size that tirerack.com told me would fit so i assumed that there would be no issues?
Old Jan 15, 2008 | 11:00 AM
fit_love's Avatar
im running 15x6.5 or 15x6 i forgot which one, but the offset is 45 and im running 195/50, lowered on tein s-techs and i have perfect clearance, no rubbing whatsoever.
Old Jan 15, 2008 | 11:12 AM
FITGD3's Avatar
For 15x6.5 rims
195/50/15 tyres are the best option to go!
Also +35 or +36 are the best offset to choose from! No problem with rub and caliper clearance! Also more aggressive look than +40 plus offset
Old Jan 15, 2008 | 12:02 PM
honda_david's Avatar
it should fit good even if you're lowered pretty low.
Old Jan 15, 2008 | 03:50 PM
Right now im not lowered at all but ill be doin that shortly after. Was lookin at tanabe df210's but that might be too low? So i might go with the gf210's
Old Jan 15, 2008 | 03:53 PM
no, check my picts in the show me your shoes thread. DF210's are not
that low.
Old Jan 16, 2008 | 02:52 PM
DF210's look good on ur car. U got 15inch rims right?
Old Jan 20, 2008 | 11:19 PM
danger69's Avatar
Not to thread jack but if I wanted to reuse my 195/55 stock sport tires with 15x7 +35 wheels on stock suspension would that work? Rubbing?
Old Jan 21, 2008 | 04:02 AM
SPON FIT's Avatar
it will rub a decent amount
Old Jan 21, 2008 | 07:00 AM
FITGD3's Avatar
It should be ok with the front. A little bit rub at rear.
Cheers
Muster
Jun 24, 2011 06:02 PM
Remedi
Jan 6, 2011 06:33 PM
mdsniper7
Oct 16, 2010 04:19 PM
panda1314
Jan 4, 2009 09:31 PM
korky
Jun 4, 2008 03:33 AM
