Re: How long do aftermarket struts tend to last (Sensatrac)? (harsh ride on 97 Accord)
Old Jun 4, 2005 | 11:09 PM
Pars
Guest
Posts: n/a
Seems like your springs are also do for a replacement.
My guess is, the aftermarket shocks are just as good as Honda's product.
But, If you want exceptional shocks, get the performance variation. I've got
200,000KM on my Tokico and their still going good. I can still blast over
railway tracks without any drama or power around bumpy roads without loosing
traction. My tires are quite noisy, since they're getting old, so I don't
notice the extra noise from imperfections in the road (It's all bad, but
that kind of noise factor is simply do to the tires...if the tires were
newer I'm sure flaws in the road would be more noticeable instead of getting
drowned out).
The Eibach Pro-Kit springs (which are progressive springs and are as
aggressive as those springs found in high performance European sedans) and
with the Tokico shocks, will return a slightly stiffer ride, but the extra
stability is reassuring. Also, this setup will better handle pot holes or
drastic railway tracks. Even with the tight springs and shocks, you'd still
have the loosy-goosy tires to soften the ride, or the option to drop in some
low profile variation to complete the package.
Pars
98 Civic Hatch
<techman41973@yahoo.com> wrote in message
news:1117771048.176842.117200@z14g2000cwz.googlegr oups.com...
> I own a 97 Accord. I replaced my stock struts at 90K with Monroe
> Sensatracs. The car has 140K now. I recently replaced my worn Michelin
> X-one tires with Goodyear Assurance Comfortred which are known for
> their smooth ride. However after replacing the tires, I noticed that my
> bumps cause shudders in the chassis and many bumps and expansion strips
> cause harsh impacts. I played around with tire pressure, which didn't
> seem to improve the ride, only worsening it. After noticing degradation
> to the rubber shock mounts under the hood, I had them replaced. The
> ride improved for a short period of time but became harsh again
> (perhaps the fresh rubber was more compliant before wearing in). Before
> I replace the struts with a new set, I would like to get some feedback
> on this. I know that Monroe recommends replacement of their sensatracs
> at 50K, however such a harsh ride seems abnormal for only 50K.
> I had them installed at Sears and Monroe brags about a "lifetime"
> warrantee. However I don't understand how they can recommend a 50K
> change interval while claiming a lifetime warrantee. Also I was under
> the impression that worn struts get floaty rather than harsh.
> I would appreciate some advice.
Stephen Lawson
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Feb 8, 2020 11:41 PM
Vsp2027
Aug 15, 2016 07:30 PM
Nvillegas
Mar 8, 2013 08:58 PM
Amageus
Feb 28, 2008 10:13 AM
gettin~Fit
Feb 11, 2008 10:23 AM
