Skunk 2 Shift Knob Question If You Have One Read Plz!!!!
Old Jan 10, 2008 | 02:56 AM
s0x's Avatar
s0x
hey guys i just got a skunk 2 shift knob and its mmmmm yummy smooth and heavy but when i screw it on as tight as i can the numbers are not str8 up like on the oem knobs ive seen a few knobs that are made for dc5s etc. and they fit the fit perfectly..i understand its diff for every car but since skunk2 MOSTLY just does honda stuff. im wondering why it wouldnt be made to fit it perfectly. AND is there any way to make it str8 up... honestly it doesnt matter but im kind of a perfectionist sometimes haha.
Old Jan 10, 2008 | 03:04 AM
sdPANNfit's Avatar
You know how it has the other screw? well you use that screw first...then you screw on the shift knob.
Then when the numbers are straight you tighten the lower screw.
cool.
Old Jan 10, 2008 | 03:06 AM
s0x's Avatar
s0x
cool.
OOOOOOOOOOH i was wondering what that screw was for. wait does that make it sit hella hi tho??
Old Jan 10, 2008 | 07:55 AM
yeamans17's Avatar
Yeah, its gonna set fairly high in the fit, I swapped mine over from my cb7 when I got the fit and I hated how high it looked, plus it felt wierd throwing that much weight with every shift in such a small car
Old Jan 10, 2008 | 08:12 AM
REXXXXXXXXX's Avatar
Frequent FitFreak Poster
Yea, i just installed mine the other day, i had the same problem, but i figured it out. Also, i was able to pull the rubber shift boot over the nut so u can't see it. The knob does sit kinda high tho =( It's also really friggin' smooth! my hand actually slipped off accidentally this morn on my way to work! I like it tho... im all about black/red =)
Old Jan 10, 2008 | 09:09 AM
Sugarphreak's Avatar
Push My Button
lol, mine tightened on perfect without the nut.... but then I took it off one day to show somebody how much it weighed and now it is scewed I tried using the nut to straighten it up, but I already got used to the position so I took it off and now it is ghetto style angled.... it drives my freinds crazy
Old Jan 12, 2008 | 03:10 AM
SD_MR_FIT's Avatar
i just rigged mine up with piece of paper shoved into the knob.
worked fine for me, perfectly straight and perfectly tightened as well.
Old Jan 12, 2008 | 03:14 AM
solbrothers's Avatar
i had the skunk2 knob on mine, but didn't like how heavy it felt. i have the mugen dildo now, and really like it. wouldn't change it for anything. except maybe to add a shift extender.
Old Jan 12, 2008 | 12:25 PM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
skunk2
I had the same problem. i took it off them put it bak in and the numbers were crooked. I just cut out to small pieces of tin foil and made them into a washers. It worked perfectly and now its even a tighter fit. You can't even see them either.
Old Feb 9, 2008 | 01:48 PM
Laylow's Avatar
Skunk2 springs
I had the same problem. I put some teflon tape, then screw the nut to tighten the knob. works perfectly.
Old Feb 9, 2008 | 02:41 PM
Push My Button
Sounds like a neat trick, I will have to try that when I put my SK2 SS in.
Old Mar 10, 2008 | 10:16 PM
The BOM's Avatar
I'm not sure if this will work on the Skunk knob... but my Honda Genuine knob came with a lock nut that you spin on before you screw the knob on. Once you get the knob straight, tighten the nut (counterclockwise) while holding the knob. It keeps you from messin up the threads by over-screwing the knob or using the locking screw too. Just an idea.
Old Mar 23, 2008 | 06:53 PM
Reinert79's Avatar
off topic but i have to LOL about the mugen dildo comment i know exactally what your talking about my buddy had the red one in his ITR a few years ago.. i was always like dude im surprised the chicks dont always wanna ride in this thing its even ribbed LMAO !!!!
Old Mar 23, 2008 | 07:39 PM
George02's Avatar
wow you dont kno how to put a shift knob on???
Old Mar 23, 2008 | 09:00 PM
jezzy's jazz's Avatar
i have this problem also, bit of a perfectionist myself but in the end its now sittin bak to front, i have all sorts shooved up inside it but still cant get it to sit straight...
Old Mar 26, 2008 | 08:26 PM
joshfalagan's Avatar
i just got mine 2 days ago by accident(sent me the wrong knob..lol) but i am not sending it back cause i love it. works great with the skunk2 short shift adapter.. i just used a couple of layers of teflon tape to make it stick better and now it doesnt move around and sits right where i want it to.
FightingChance
SoCal Classifieds
Feb 3, 2015 02:25 PM
Chad T
Nov 20, 2009 03:42 PM
parkerdt
Jun 4, 2009 12:57 PM
Crawly
Jul 18, 2007 10:27 AM
FitSam
Dec 15, 2006 07:06 AM
