Rain leak, CR-V, 2001
Old Jun 5, 2005 | 03:06 PM
Lanning
Guest
Posts: n/a
What is the chance that the dealer replaced the cabin air filter in such a
way that rain would get in?
The carpet is getting wet on the front passenger side between the seat and
the door, but it doesn't seem wet under the dash.
Thanks for any help.
Roy
Old Jun 6, 2005 | 03:11 PM
Andy Fekete
Guest
Posts: n/a
Re: Rain leak, CR-V, 2001
Does your CR-V have a sunroof? If so, you may have a clogged sunroof drain
hole. The drain hole is in the front corner of where the sunroof meets the
roof. It gets clogged occasionally with leaves, etc. Just take some
compressed air and blow it out, or run a coat hanger down to get the
obstruction out.
Good luck..
Andy
"Lanning" <LanningREMOOVE@THIScox.net> wrote in message
news:dDHoe.34421$Fv.21815@lakeread01...
> Roy
motsco_ _
Guest
Posts: n/a
> Roy
It's not the dealer's fault. There's a known problem with the plastic
windshield cowl on the first Generation Cr-v, where the foam rubber
isn't aligned correctly. Park your CR-v on just the wrong angle and the
rain will drip straight into your fan motor all day. Start here for an
insight into the cure. Sign in and search for more. Some folks replace
the foam, others install a 'hood' inside the heater to deflect the
dripping. The cowl has to come off either way.
http://www.hondasuv.com/stg/viewtopic.php?t=9893&
'Curly'
Lanning
Guest
Posts: n/a
Curly,
Thank you very much. I'm in that forum, but haven't been there in years.
Used to visit routinely. I just tried, and I can still log in. It looks even
better than before.
Roy
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:42A3A04B.9090502@interbaun.com...
a
and
| > Roy
| 'Curly'
iceblue
Jul 28, 2023 02:18 PM
lesterlai12
Aug 17, 2022 06:41 PM
vonBobo
Aug 22, 2016 09:37 PM
tehmaxfactr
Mar 10, 2009 08:00 PM
HaroldWho
May 4, 2005 11:16 AM
