HELP! on rear strut bar
Old Jan 11, 2008 | 08:52 PM
BlazeOrangeFitTuner's Avatar
I recently recieved my Tanabe front/rear strut bars. In the process of trying to take the nut off for the rear strut bar and I accidently stripped out part of the allen wrench hole. Now I can't get the allen wrench in the hole very far. Any advice on what to do
Old Jan 11, 2008 | 08:53 PM
JDMchris.com's Avatar
I run THIS
vice grips
Old Jan 11, 2008 | 08:54 PM
use vice grips on the threads?
Old Jan 11, 2008 | 09:07 PM
HONDAMATIC's Avatar
impact gun
Old Jan 11, 2008 | 09:27 PM
wrap a rubber radiator hose (or similar) over the threads and use
channel locks (large pliers) to hold the shaft while you turn the nut.
make absolutely sure you DO NOT damage the thread cause it will
make it a huge pita to remove it next time.x
Old Jan 11, 2008 | 09:55 PM
the rubber sounds like a good idea im going try this right now, but has anyone else ran into this mistake? and if so what did you do?
Old Jan 11, 2008 | 11:01 PM
you put a standard key into a metric key probably...
Old Jan 12, 2008 | 12:51 AM
Whitehybrid's Avatar
my thoughts exactly...
some people shouldn't be near tools...
Old Jan 12, 2008 | 10:24 AM
no i didnt do that, i know that its metric. i thought i had it in the hole all the way but it was only half way in, so now the top half of the hole is stripped out and i cant get it in all the way in to the bottom.
Old Jan 12, 2008 | 10:39 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
The rear bar was much easier for me to remove than the front , because you didnt have to stick your hands up in the wheelwell and not see them
Old Jan 12, 2008 | 01:08 PM
ok one more quick question, do i keep the metal washer under the nut on or take it off????
Old Jan 12, 2008 | 02:03 PM
solbrothers's Avatar
leave the washer. iirc
Old Jan 12, 2008 | 02:38 PM
so the worst two days of my life are over i got the stupid thing on! i had to hammer the allen wrench in and grind down a wrench to fit in between the support for the bar, but i did take the washer off because it doesnt show it in the instructions and the bars feet are almost the same size as the washer. o well i guess, but thanks for all the help you guys gave me. this is almost as a bad as when i hit that chunk of something in the road!
Old Jan 12, 2008 | 02:41 PM
George02's Avatar
damn on just a strut bar!?!?!? Im amazed
Old Jan 12, 2008 | 05:53 PM
yah, more bad days to come little one. kidding kidding. hahaha.
fillit
May 17, 2011 04:00 AM
revd34
70
Jul 15, 2009 02:40 PM
Bragi
18
Jun 20, 2009 02:22 AM
keepitpg
Jan 19, 2009 04:52 AM
MNfit
13
Jan 1, 2008 04:41 PM
