Honda CR-V 2003: can the 12 volt outlet be 'always on'?
Old Jun 13, 2005 | 03:26 PM
Z Man
Guest
Posts: n/a
In my CR-V, the 12 volt outlet (which in the old days was used for a
cigarette lighter) is not powered when the vehicle is not powered. I have a
GPS unit that plugs into the 12 volt outlet, and maintains certain
information when powered. If I stop for a moment to go into a store, for
example, and turn the engine off, that data is lost (and it also takes a
little while for the GPS to find the satellites again). Can the car be
modified such that the 12 volt outlet wills stay powered even when the
vehicle is off?
Seth
Guest
Posts: n/a
Re: Honda CR-V 2003: can the 12 volt outlet be 'always on'?
"Z Man" <z1z@hotmail.com> wrote in message
news:4IXqe.588$Gy3.538@fe12.lga...
> a GPS unit that plugs into the 12 volt outlet, and maintains certain
> vehicle is off?
If you don't mind a little under dash wiring it is very easy. Just run a
line from the hot side of the accessory outlet to an always hot circuit at
the fuse panel. Use an inline use to protect the circuit and cap off the
now unused like at the outlet.
Z Man
Guest
Posts: n/a
"Seth" <seth_lermanNOSPAM@hotmail.com> wrote in message
news:e3_qe.521$yg4.386@news01.roc.ny...
>> vehicle is off?
Actually, I do mind :) I know nothing about cars, and am doing the best I
can to keep it that way. Do you think I could pay Honda to do this
modification for me? If it is that easy, they shouldn't charge much.
Brian Stell
Guest
Posts: n/a
>>>vehicle is off?
You can probably find a local car car stereo shop to do this
Brian Stell
Guest
Posts: n/a
>>>> have a GPS unit that plugs into the 12 volt outlet, and maintains
>>>> certain information when powered. If I stop for a moment to go into
>>>> a store, for example, and turn the engine off, that data is lost
>>>> (and it also takes a little while for the GPS to find the satellites
>>>> again). Can the car be modified such that the 12 volt outlet wills
>>>> stay powered even when the vehicle is off?
>>> run a line from the hot side of the accessory outlet to an always hot
>>> circuit at the fuse panel. Use an inline use to protect the circuit
>>> and cap off the now unused like at the outlet.
>> best I can to keep it that way. Do you think I could pay Honda to do
>> this modification for me? If it is that easy, they shouldn't charge much.
and you might want to cut the wire to the lighter and reconnect it to
hot. You probably don't want to just connect it (uncut) to hot. I
believe that would make all switched devices always on.
Seth
Guest
Posts: n/a
news:xU5re.7328$S62.3109@fe11.lga...
>>> certain information when powered. If I stop for a moment to go into a
>>> store, for example, and turn the engine off, that data is lost (and it
>>> also takes a little while for the GPS to find the satellites again). Can
>>> the car be modified such that the 12 volt outlet wills stay powered even
>> at the fuse panel. Use an inline use to protect the circuit and cap off
I doubt a Honda dealer would do this. Like Brian said, find a stereo shop
to do it for you.
amszterpeter
Feb 16, 2015 09:40 AM
CIOWN
Oct 10, 2014 12:34 PM
hogsniper
Mar 13, 2008 06:22 PM
sam
Jun 10, 2005 06:34 PM
John W. Barron
May 4, 2005 04:44 PM
