Is 5W-20 spec'd globally or is it North America only?
Old Jan 24, 2008 | 06:29 PM
richard612's Avatar
Question Is 5W-20 spec'd globally or is it North America only?
What is the recommended oil viscosity outside of the US and Canada?
For EU Jazz owners, is there an ACEA oil spec that you should follow?
Old Jan 25, 2008 | 02:14 AM
claymore's Avatar
There are MANY different viscosities and specification of oils for different parts of the world. Take a look under specifications and maintenance schedules.
http://www.hondafitjazz.com/manual.htm
Old Jan 25, 2008 | 05:24 AM
RubyQQ1211's Avatar
I don't know much about oil, so can I put something else other than 5w-20? I read a lot of posted about it, and I still don't get it.
Old Jan 26, 2008 | 07:26 AM
Carbuff2's Avatar
You can use 5W-30 without worry, at a slight expense of some fuel economy. It is commonly available in the USA.
But if you can find the 5W-20, go with that. You may have to go to an autoparts store to buy it.
Hondas, Fords, and Chryslers have all spec'd 5W-20 since about 2002...it's not THAT difficult to find.
Old Jan 28, 2008 | 10:55 PM
stew32's Avatar
Using 5w-30 instead of 5w-20 can cost 1-2 MPG. Probably not enough to notice unless you religiously keep track of it.
I tried this in my 1.5 L Toyota. The factory spec was 5w-30, then Toyota issued a TSB changing to 5w-20. I tried both. I had 5w-30 in it, then change to 5w-20. Used the same oil brand, identical filter, drove the same day on the same stretch of road. ScanGauge read between 0 and 3 MPG better at various sections after changing to 5w-20. Mostly 0-1 MPG. But the Toyota didn't seem to like the lighter weight- noticed more valve train noise. No such noise with the Fit running 5w-20 so no reason not to use it.
The only difficulty I've had is finding the big 4 or 5 quart jug of 5w-20 in a conventional oil. The only 5w-20 I've found stocked is the big jug of Mobil 1.
Old Jan 29, 2008 | 11:07 AM
richard612's Avatar
Thanks for the info. While we're on the subject of oil specs, I'm assuming that Honda MTL is the universal gearbox lube for these things?
Old Jan 29, 2008 | 07:03 PM
Carbuff2's Avatar
Thumbs up
Correct.
The NEW Honda MTL is even better. I changed the MT fluid in my CR-V and I really could tell the difference. I expect to put it in the FIT this summer, after the car gets about 15K miles on it.
Old Apr 5, 2008 | 01:59 PM
richard612's Avatar
Bumping this thread. Still wondering what oils are specified for the Fit/Jazz in other countries. I haven't really found anything so far. I never saw any viscosities listed in the manuals to which Claymore linked.
Zardiw
Jul 29, 2016 09:07 PM
n9cv
Jul 1, 2014 10:01 PM
J3SS13
May 9, 2011 01:27 PM
Eugene.Atget
Dec 11, 2010 07:21 PM
mav238
Sep 18, 2010 07:29 PM
