SPOON Sport 4 Pot Mono-Block Caliper
Old Feb 6, 2008 | 02:26 AM
clearwhitesky's Avatar
Hi!,
I got a Spoon 4 pot mono-block caliper from a friend who was previously driving a DC5.
My Question:
I'm driving a JDM 1.3 Honda Fit w/ L13A engine. Running on a set of Spoon 15" wheel w/ BC coilover.
I like my current wheel very much so is there anyone here is running on Spoon 15' wheel + Spoon Mono-block.
Was wondering if the caliper be able to clear this 15' rim and what is the max diamension disc to clear? 282mm?
Old Feb 6, 2008 | 02:33 AM
kelsodeez's Avatar
UNBANABLE
the opak racing spoon fit has the spoon monoblock brake setup with 15in sw388
Old Feb 14, 2008 | 01:49 AM
ToyotaLover's Avatar
contact AJ-Racing as they have run the 15" wheels with Spoon calipers. They have more info on that.
Old Feb 14, 2008 | 06:30 AM
I've email OPAK Racing on their fit with spoon caliper. Here are the conversation.
Chris,
Monoblock calipers won't work for the Fit.
You need the twin block calipers.
Call us. 650 952 1900.
We have strut bar for the Fit. Brake pads etc...
Ask for Edmun
PS. Call me on Thursday. Friday we are racing at Infineon.
But anyway i'll be heading down locally to get the caliper fix onto my ride tomorrow and at the same time to do a rear disc convertation. Will Show you guys the photos once it is ready.
Old Feb 14, 2008 | 06:41 AM
azkikersfit's Avatar
tagged for interest, let me know on how it goes and dont forget Pics.
i was thinking of goin for the NEX bbk but i m curious about this Spoon set up. How much did u get em for? good luck on dat !!
Old Feb 14, 2008 | 08:31 AM
Zangoose GD3 Blue's Avatar
well aspec told me that the EG spoon calipers would fit on the FIT...
Old Feb 15, 2008 | 10:37 AM
DONE! Managed to get it up even using the original Spoon Sport Caliper Bracket for DC5. Just need to add 4 customed bushing. Can consider it as a direct bolt on. But need to change the wheel studs and add spacer.
I'm using a VTTR 286mm disc.
Please enjoy.
Old Feb 15, 2008 | 11:54 AM
kelsodeez's Avatar
UNBANABLE
damn that looks good. almost makes me want to trade my project mu calipers for spoon ones and keep the rotors.
Old Feb 15, 2008 | 12:28 PM
dat shit is tyt!!!
so how much did u get em for ? and where did u get em?
Old Feb 15, 2008 | 01:06 PM
Please enjoy.
What disk are you using? (what car?)
would you like to explain what type of spacers and where? THink a 2pcs rotor would fit? I'd love to use that rotor size and even get a 2pcs in there saving potentially even more weight.
what is the difference in weight from that caliper to our stock calipers?
Old Feb 15, 2008 | 07:49 PM
Depend on the rim you're using... For me, i'm using a 15' Spoon Sport SW388 Rim. For that I'm i'm goin with a single layer VTTR 286mm disc and i have to replace my wheel studs to a longer one as i'm adding additional 8mm spacer.
As for caliper bracket... strange enuff i'm using a Original Spoon Sport Bracket but it is meant for DC5. I've to add additional 7mm bushing to space out the bracket if not the disc won't fit. (again the bushing length have to depend on the disc you're using, different disc different offset.)
Basically additional stuffs i need to fix the mono-block caliper is:-
02 x 7mm bushing (to space out the Spoon Caliper Bracket from the knuckle)
02 x 5mm bushing/washer (to space out the Spoon Caliper from the Spoon Caliper Bracket - Depend on the diamension of the disc you're using, the larger the disc, the thicker the bushing/washer.)
1 set of Honda Civic wheel stud (this is to compensate the lost of srew tread of the stud when adding wheel spacer)
1 x 8mm wheel spacer (this is also have to depend on the type of rim you're using, different rim have different offset.)
Old Feb 15, 2008 | 08:52 PM
quick question i was going ask about the calipers how much did the calipers cost you bro...
Old Feb 15, 2008 | 09:02 PM
just caliper alone SGD 2.8k
Old Feb 15, 2008 | 09:04 PM
kelsodeez's Avatar
UNBANABLE
1900 usd! damn! expensive for repackaged nissin calipers.
Old Mar 4, 2008 | 12:07 AM
aallbbeerrtttttt's Avatar
The calipers he has are the Monoblock calipers, much more expensive than the twin-block calipers used on EG/EK/DC2's
To put twin-block calipers onto a Fit, call Opak Racing, they can supply you with everything you need, basically, you can bolt the caliper on with no problem, but you need to run a custom offset rotor, which they offer, then it's just bolt on affair
Old Mar 4, 2008 | 04:03 AM
AJ PwR Jr.'s Avatar
Former Vendor
Here's some info for Spoon twinblocks fitting onto the USDM Fit. You will need the following :
- Spoon Twinblock calipers
- any pads that fits Integra Type-R will fit with the Spoon twinblock calipers
- 282mm rotors **You can use 92-96 Prelude VTEC rotors 4H114 redrilled to 4H100 to fit**
- 3mm under rotors spacers will be needed to center the rotors to the calipers
Please enjoy.
There will be some issues running the Monoblock calipers (reverse type) with the Fit. The piston should be compressed from smaller piston then to the bigger piston according which side the caliper sit to the rotor. If you use the MONOBLOCK, the bigger piston will be compress first then to the smaller piston then this will seriously affect intial and mid speed braking.
If you want to go MONOBLOCKs you will need to get the ones which are the FORWARD Type from Spoon.
scarygoldlion
Dec 7, 2007 07:39 PM
blackgd3
Jun 29, 2006 02:57 PM
ICantFit
Apr 3, 2006 05:19 AM
Sleeper
14
Dec 19, 2005 05:17 PM
Jonniedee
Dec 16, 2005 06:02 AM
