1993 Honda prelude vtec
Old Jun 22, 2005 | 01:43 PM
cocococo1
Guest
Posts: n/a
I have had the car standing for a couple of weeks and have been trying to
get it started to use it and I have no fuel pressure at all.
Spark present but no fuel at all.Possible fuel shut off relay but not sure
where it is or which relay as all wriiten in Japanese.
Any help please.
motsco_ _
Guest
Posts: n/a
Re: 1993 Honda prelude vtec
> Any help please.
If you've disconnected the fuel line and are sure there's no fuel
pressure, put the key in position II, and smack the dash on the left
side of the steering wheel. You'll hear the fuel pump run. Is it fairly
WARM where you are?
If you haven't proven (conclusively) that there's no fuel pressure, hold
the pedal to the floor and crank the starter for up to fifteen seconds.
It's way more likely that your engine is flooded. Your owner's manual
says that a flooded engine can started that way. Your fuel relay won't
fail by itself while "standing for a couple weeks", but your leaking
injector can drain all the pressure out of the fuel rail and flood the
engine. It can happen overnight too. It happened to my Odyssey. I ran
two tanks of Gasohol thru it and it never happened again.
'Curly'
Old Jun 23, 2005 | 11:43 PM
cocococo1
Guest
Posts: n/a
I have tested my main relay and it seems as though all is well, ae there
fuses covering the supply to this unit and if so does any one know where
they are on this model.
Many thanks
Vic
BMW ALPINA
Feb 3, 2018 12:27 PM
Myxalplyx
May 11, 2016 12:29 AM
clanbuster
Mar 18, 2010 02:45 PM
hsnt
Nov 5, 2009 04:47 PM
bayneman
Oct 11, 2005 10:35 AM
