1997 "Honda Tap"?
Old Jun 28, 2005 | 04:04 PM
sweety783
Guest
Posts: n/a
1997 "Honda Tap"?
The valves in my Honda are VERY loud. I've had the valves adjusted several
times by different mechanics but its done nothing. I've been told that its
not hurting anything but the noise is endlessly irritating.
Is there anything I can do to eliminate or soften this noise?
Thanks for all your help.
E Meyer
Guest
Posts: n/a
Re: 1997 "Honda Tap"?
On 6/28/05 2:16 PM, in article
f9147e654ac2353c3991047db36861e2@loc...o utautos.com, "sweety783"
Have you ever had the valves adjusted by a Honda shop? Try getting the
valves adjusted at a Honda dealer to make sure thatıs not the problem.
It might not be the valves, though. It might be piston slap. The 4
cylinder engines of that vintage were susceptible to it. Does it only do it
when the engine is cold and then quiet down after it warms up? If it is
piston slap, it doesn't really hurt anything and the fix is a new engine.
Most people just learn to ignore it.
Old Jun 28, 2005 | 04:33 PM
sweety783
Guest
Posts: n/a
Re: 1997
E.Meyer, Thanks for both replies. I will bring it to a dealer and have
them check out what you said.
Thank you very much
Old Jun 28, 2005 | 05:34 PM
MAT
Guest
Posts: n/a
"sweety783" <sweety783@msn.com> wrote in message
news:f9147e654ac2353c3991047db36861e2@localhost.ta lkaboutautos.com...
> several
> its
It is also extremely important to adjust valve lash with stone cold engine.
When I adjust mine, I leave the car at my parent's house and come back a day
or 2 later and do it with a cold engine.
Old Jun 29, 2005 | 01:56 AM
Kevin McMurtrie
Guest
Posts: n/a
In article
<f9147e654ac2353c3991047db36861e2@localhost.talkab outautos.com>,
Which car? On my 97 Civic HX, oil adhering to the moving parts would
cause me to set gaps up to twice as large as spec'd. I found the
solution - pull up hard on the rocker then hold it up lightly with a
finger. The measurements would then be very accurate and consistent.
Old Jun 29, 2005 | 09:42 AM
sweety783
Guest
Posts: n/a
Re: 1997 Honda Accord
Thanks for your help. It's a 1997 Honda Accord DX.
dirtybird222
Sep 29, 2016 10:31 PM
swiftmove
Jul 7, 2013 02:17 AM
Pith
Mar 20, 2011 12:30 PM
fm2n
Aug 2, 2006 12:40 AM
chibitul
Aug 10, 2005 06:31 PM
