601(whp) Turbo Honda S2k
Old Mar 3, 2008 | 05:10 PM
tonyd3773's Avatar
A pretty kool video of a HONDA S2000 putting some serious power down....enjoy.
Mase Engineering and Stage 6 Motorsports 600whp ST - Video
Old Mar 3, 2008 | 05:17 PM
Zangoose GD3 Blue's Avatar
looks like its not moving as fast as it should be going... IMO but great video as always
Old Mar 3, 2008 | 05:18 PM
TOOL's Avatar
Siick video!
Thats insane power!!! Too much power for that car IMO.
S2000 S2k - Midnight-Crew.com - Video
^Same car??
Tyler
Old Mar 3, 2008 | 06:57 PM
gn-it&rn-it's Avatar
not the same car... the one on the dyno has the driver on the right side. Still cool though!
Old Mar 4, 2008 | 09:05 AM
07fitsport's Avatar
yeah still nice video.
FiT happens!
Old Mar 5, 2008 | 03:30 PM
jits14's Avatar
How bout this one? Its for sale too!
I have a 2001 S2000 with a 2JZ-GTE Toyota Supra Turbo motor swap. The car has 42k miles on it and the motor has about the same because it is a JDM 2JZ-GTE motor from Japan. There are only 3,000 miles on this build. The 2JZ has a single turbo conversion with a GT45 T88 turbo on it. The Supra Getrag 6 speed manual transmission is also mated to the 2JZ. This tranny will hold 1500hp! $28500
This is the 6th and latest 2JZ S2000 in the world. Here is a list of some mods:
JDM 2JZ-GTE Toyota Supra Turbo Motor
GT45 T88 Turbo
Single Turbo Conversion
Supra Getrag 6 Speed Manual Tranny
Comptech Rear Differential fully Cryo Treated for greater strength - This diff is new and still needs to be broken in. I would go easy on it for the first 500 miles and change the diff fluid. After that you should be good to go.
HKS Wastegate
HKS SSQV Blow-off valve
TurboSmart manual boost controller
Aeromotive Fuel Pressure Regulator
Walboro Fuel Pump
Front Mount Intercooler
Steel braided coolant lines
Battery relocation kit - to the trunk
Short Shift kit
Solid Titanium Shifter Mounts
Sparco Shift Knob
ACT Clutch
ASA 17" Wheels
Greddy oil cap
Cobalt boost gauge
Cobalt water temp gauge
Autometer Carbon Fiber Ultra-Lite Speedometer
Pillar mounted gauges
AFC Neo
Custom Turbo-back exhaust
Brand new Convertible Top
New bearings
Greddy Boost Cut Control (BCC)
Many hours worth of polishing under the hood
Titan Cam Gears
New NGK spark plugs
New Timing Belt
New Water Pump
Recent Alignment and Balance
I'm sure there are some things I missed, but you get the point. This car is an absolute beast. Even with the motor swap, the S2000 only weighs in at ~2900lbs. I have already changed the oil and filter 3 times in 3,000 miles to ensure complete and proper break-in. The first change was with Castrol motor oil. The last two I used Mobil 1 10w30. The car does not have a center console cover. I was planning on getting a custom one made to fit the Getrag 6-speed, but it does not bother me to just have the carpeted console. The stock speedometer and rpm gauge does not work due to the engine swap - the stock sensors are calibrated for a 4 cylinder not a 6. I use the AFC Neo as a digital RPM gauge (more accurate) and the Autometer Carbon Fiber speedometer.
This car is an absolute Beast. It will break traction at 80mph under boost! Currently, the car is only tuned to 15 lbs. of boost on pump gas (extremely conservative for a 2JZ). With 25 lbs. of boost and some race gas, the 2JZ S2K will be unmanageable unless you get some Drag Radials.
I have over $20,000 in parts and labor invested in this S2000. My loss, your gain. I've only put 3k miles on the car since it was completed in July 2007. The car is located in Nashville, TN. If you have any further questions, please call me on my cell phone (512-771-2528). Anyone is welcome to come check the car out in person. I will be happy to give you a ride in it. Here are some pictures of my car:
Here is a quick video of my car. This is a 50mph-150mph pull starting in 3rd gear. I am short shifting in every gear at ~6300rpm (rev limit is stock @ 6800rpm) except for 3rd when you can hear me hit the rev limiter. At about 140mph I let off considerably and kind of coasted to 150mph before completely shutting it down. Sorry about the poor quality. Turn your speakers up!
Old Mar 5, 2008 | 08:53 PM
tonyd3773's Avatar
GT45 T88 Turbo
HKS Wastegate
Walboro Fuel Pump
Short Shift kit
Sparco Shift Knob
ACT Clutch
ASA 17" Wheels
Greddy oil cap
Cobalt boost gauge
AFC Neo
New bearings
Titan Cam Gears
New NGK spark plugs
New Timing Belt
New Water Pump
Nice whip....haven't seen a 2JZ engine swap into a S2000!!! SWEET.....but a rep point would be sweeter for ur plug on my thread....lol.
peace,
Old Mar 6, 2008 | 09:29 AM
07fitsport's Avatar
nice but does it have a cigarette ligther
HB1320
23
Apr 29, 2011 06:01 AM
tonyd3773
Jun 26, 2008 05:57 PM
tonyd3773
Jun 20, 2008 02:56 PM
tonyd3773
Mar 29, 2008 12:20 PM
tonyd3773
Mar 23, 2008 12:55 PM
