Axle/Transmission/Engine makes gurgling noises on cold starts
Old Mar 21, 2008 | 11:48 AM
sw20's Avatar
Hi All:
I've had my FIT since 05/2006...Lately been hearing this funny noise from my car usually in the morning or when I leaving work because the cars been sitting for awhile. Basically on cold starts. When I would gas the car I could hear this gurgling or sounds like water rushing back then when I brake I hear it again. It only happens around 5-15mph and after the car warms up the sound goes away.
My parent's have a simiar problem with the 97 camry but there's never goes away. Does anyone know what could be causing that sound?
Any ideas would be appreciated..Thanks
Old Mar 21, 2008 | 12:12 PM
JDMchris.com's Avatar
I run THIS
its the gas in the tank.
Old Mar 21, 2008 | 12:18 PM
you're either hearing the gas moving around as posted above, or
you got air in your cooling system.
Old Mar 21, 2008 | 12:21 PM
sw20's Avatar
Hi JDMchris.com,
Are you sure, because the sound comes around where the gas pedal is. I thought it might be the gas tank because I've read a lot on it, but I thought our gas tank was under our seats?
Old Mar 21, 2008 | 12:25 PM
sw20's Avatar
Thanks kenchan,
I'll look into the cooling system..I gotta look to see if that was part of the 30k mile tune up that I recently did...That might have been when the noise started...cars at 39k now so that is a good possibility. Thanks..
Old Dec 22, 2008 | 04:46 PM
Fieldstone's Avatar
It's the cooling system...not the gas tank. SB out on this.
riff42
Dec 28, 2011 03:35 PM
Sima
Jan 9, 2010 09:18 PM
Committobefit08
Jan 27, 2009 07:27 PM
fit73
Feb 11, 2008 03:36 PM
sam21
Aug 31, 2007 04:08 AM
