does the odo still count if your engine ins off?
Old Apr 9, 2008 | 11:11 PM
pastafarian's Avatar
SInce ppl turn the engines off when the draft, i was curious if the odometer works while the engine is off. If not then actuall it will appear you get fewer miles per gallon
just curious
Old Apr 9, 2008 | 11:13 PM
solbrothers's Avatar
if you want to rid your fit of miles, just drive backwards. haven't you seen ferris bueller's day off?
Old Apr 9, 2008 | 11:37 PM
Black01's Avatar
I would say no. You're mileage should not go up because mileage shows how many miles the engine was used. So if your car is off, of course the engine is not running.
Old Apr 9, 2008 | 11:42 PM
Kelmar's Avatar
Frequent FitFreak Poster
^ Is correct. It does not track the mileage when the car is off. Usually this is considered illegal in most states (called coasting), so use caution.
Old Apr 9, 2008 | 11:43 PM
if the engine is off, you don't have power steering and you don't have power brakes. don't do this please.
Old Apr 9, 2008 | 11:45 PM
Kelmar's Avatar
^Agreed!
IMO, turning off the engine at long red lights is one thing, but turning it off when driving is something completely different.
Old Apr 9, 2008 | 11:48 PM
^Agreed!
yeah. im not gonna lie, i did this one late night *no other cars on the freeway with me* i'd never consider this on a daily basis. the gains just aren't there.
i'd only turn my car off at railroad crossing. even at a red light, i don't want to look like a jackass if the car doesn't start for some odd reason LOL
Old Apr 10, 2008 | 02:47 AM
ToFit2Quit's Avatar
Turning your engine off while your gears are engaged? I don't recomend it at all. That'll actually ruin the engine. Also note that if you put it on Neutral and rengage it without the proper rev matching on the correct gear, it can produce enough wear and tear to destroy your engine and/or transmission. You're trying to save a couple of bucks, but risking a couple of thousands in repairs. Is it really worth it?
Old Apr 10, 2008 | 03:10 AM
Snap Fit's Avatar
I recall a somewhat recent thread (couple of months ago possibly) where a mod and a user both said that they retained power steering when the car was off and coasting. We thought it had to do with the car having electric assist power steering and being left in the number two position. But I don't remember if it was just the ease of using the wheel unaided at speed or if it actually was still (inconsistently though) using power steering.
And the brakes don't seem to dreadfully succumb to unaided assist right away.
I am not condoning anything I just thought those things were interesting to note, albeit...inconsistent.
sorry for going off topic...
peace out
Old Apr 10, 2008 | 06:56 AM
dank24's Avatar
classic classic
Old Apr 10, 2008 | 09:27 AM
peace out
STILL. i deleted the PS on my del sol when i swapped it. not having PS is meh. but not having brakes. that is stupid and potentially deadly
Old Apr 10, 2008 | 03:22 PM
AppleMac*Fit's Avatar
Yeah - this was covered a few weeks ago.
If the car is off, but the ignition is in Accessory-2, the brakes still work and the steering still work. Although you will not have power assist for the brakes or the power steering. No big deal, though.
EDIT - oops, you asked about odometer. YES, it still works if you're in Accessory-2 (the same position it is in if the car is running). So basically you put the car in neutral, allow the RPM of the engine to come down to neutral, turn the car's ignition switch to off, then back to Accessory-2. The odometer will continue to count, the brakes / steering will continue to work. All is well, and you're getting infinite fuel economy.
Old Apr 10, 2008 | 06:09 PM
yes the brakes work, but not NEARLY with the same force as with the engine runnign
Old Apr 11, 2008 | 09:44 AM
pcs0snq's Avatar
Apple Mac Knows!
I would add that the brakes will work as normal with eng off for many brake applies or pumps before the vac reserve is depleted. On my Fit it's at least 6 applications of the brakes. When that occurs they still work, just need more force. So for sure if your legs are weak don't consider doing that.
Old Apr 11, 2008 | 09:59 AM
if you don't want to kill anyone, don't do that.
ps. the scangauge is off when the engine isn't running. so that'll throw off your mileage that way :P
Old Apr 11, 2008 | 10:02 AM
pcs0snq's Avatar
Old Apr 11, 2008 | 08:48 PM
thx for the info not so much for the $0.02. I dont do this, i was just wondering.
Old Apr 12, 2008 | 11:57 AM
grouser's Avatar
Here's three pages on the pro and cons of coasting,,,
https://www.fitfreak.net/forums/fit-...tral-safe.html
Old Apr 12, 2008 | 01:09 PM
pcs0snq's Avatar
Has anyone else looked at the $'s with this?
I did and now will not do it as much. I was just doing it at or approaching lights or known long stops and not at hi-way speeds.
I counted 7 min at idle I avoided on my 52 mile to and from work commute.
SG says idle fuel usage is .25 to .30 gph
7 min seemed like a lot, but unless my math is off that's
around 29hrs/year or
less than 9 gal of gas or
$30/ year at current gas prices.
Not as attractive as it FEELS
Anyone dare to check that???
Old Apr 12, 2008 | 09:36 PM
Hmm...
Let's say 0.30 gal/hour.
My longest light is 5 minutes (usually the only light at which I shut the ICE off).
5/60=0.0833 hours * 0.30 gallons
= 0.025 gallons of fuel saved (for 5 minutes off). --->NOT counting to restart the engine.
0.025 gallons * $3.20/gallon = $0.08 saved (1-way)
$0.08 * 2 = $0.16 or 0.050 gallons (round trip work trip, 1 day)
5 days (per week) * 48 weeks (per year... 1 month vacation) = 240 days commuting to/from work
240 trips * $0.16 (cost to idle at the red lights) = 12 gallons of gas = $38.40 / year
Makes me wonder if turning of the ICE is worth it at the light. Since I idle all the way to the light, I usually don't wait much for lights... Makes me think...
